63 unibody build
Posted: October 30, 2010, 6:51 am
I will post all the pics for my "63 unibody custom cab", as I relocate them, since i've owned this truck for 30 years now.
I am in the process of updating the front end by installing an independent front suspension with power disk brakes.
(therefore removing the old straight axle with leaf springs)
Power steering is also in the mix which includes a new tilt steering column (the 83 mustang H.O. 5.0L has the power unit for which I have not hooked up because I was still with the original steering box)
I installed the 83 engine in 87, the engine had just under 40k, hooked up to a 3 speed / overdrive s-rod manual trans from a capri
The truck will be lowered 3 inches from its existing stance.
Next on the list is finishing the interior, headliner, door panels seat?.
Cheers
- reposting from members area / projects & builds at a members suggestion to get better exposure... Thanks Grits
Cheers
