BRAKE DRUM SELF ADJUSTER KITS PART NUMBERS
Links for Slick related sites and venders
jhewitt
Post by jhewitt »
After much weeping and gnashing of teeth with local parts stores I found the following p/n's that allowed me to get these parts locally, BUT the online prices was much better, the following was listed FOR
1965 FORD F-100 5.8L 352cid V8 : Brake/Wheel Hub : Drum Brake Self Adjuster Repair Kit
I found our local Advance Auto Parts used the SAME p/ns 2540 and 2541 but WITHOUT the preceding letters as listed below, THEIR computer listings showed NO SUCH KIT for my truck, the following came from
http://www.rockauto.com
BENDIX Part # H2540 SELF ADJ. KIT(WHEEL)
2 Wheel drive; Rear drum brake 11 1/32" x 2 1/4"; FRONT LEFT
2 Wheel drive; Rear drum brake 11 1/32" x 2 1/4"; REAR LEFT
BENDIX Part # H2541 SELF ADJ. KIT(WHEEL)
2 Wheel drive; Rear drum brake 11 1/32" x 2 1/4"; REAR RIGHT
2 Wheel drive; Rear drum brake 11 1/32" x 2 1/4"; FRONT RIGHT
DORMAN Part # HW2540
Rear Left; 11" x 1.75"; RWD; FMSI No.283
Front Left; 11" x 2"; RWD; FMSI No.282
DORMAN Part # HW2541
Front Right; 11" x 2"; RWD; FMSI No.282
Rear Right; 11" x 1.75"; RWD; FMSI No.283
RAYBESTOS Part # H2541
Rear;Right;Two Wheel Drive (4x2);
Front;Right;Two Wheel Drive (4x2);
RAYBESTOS Part # H2540
Rear;Left;Two Wheel Drive (4x2);
Front;Left;Two Wheel Drive (4x2);
CENTRIC Part # 11967002
RWD; Front Right
RWD; Rear Right
CENTRIC Part # 11967001
RWD; Front Left
RWD; Rear Left
WAGNER Part # H2540 {#F98370S}
Rear; L.H.; 2WD
Front; L.H.; 2WD
WAGNER Part # H2541 {#F98371S}
Rear; R.H.; 2WD
Front; R.H.; 2WD
Griffin GA 1965 F100
Have 3, one daily driver others in different state of repair/disrepair
jhewitt
Post by jhewitt »
What I have found with MOST of my local parts stores they have men or women with no or very little vehicle knowledge or they can't look up anything UNLESS they go through ALL the screens, AND the YEAR I give 1965 almost automatically get's you a well we don't go back that far or I doubt we can get that, so what I have learned to do which may help you is I start by asking do you carry BENDIX / DORMAN / RAYBESTOS / CENTRIC / WAGNER brake parts, THEN if they carry one or more of these then I give them the p/n.
