Stock Height Question
Here is my situation guys, I bought new coils for my truck because the others were just plain worn out. Now my truck sits wayyyy to high in the front. The wheels are all out of wack because of how high it sits. I was just wondering about where the truck was supposed to sit from the factory. I measured to the bottom part of the cowl where it meets the fender and got about 40 1/4" from the ground. Could one of you guys with a stock height truck give me a measurement to your cowl in the same spot to give me an idea of where I'm supposed to be?
65' Original 4x4 F-100 and 65' 2wd F-100
William-in-St George
Springs
I'd guess you have the wrong springs or you installed them wrong? Compare the new with the old and see if there is an obvious difference. And can you take them back? Then go to eaton detroit spring and get the right ones. They also have a web page for questions.
William-in-St. George
I just measured mine. It's 38 3/4" to the bottom of the cowl. Mine's wearing 235/75-15's. What tires are you running?
William in LA (Lower Alabama)
1966 F100 SB - 352/3spd
1965 F100 SB CC - sold
1966 F100 SB CC - sold
1966 F250 Work body - sold
1967 F100 SB CC - 360/C6 - sold
1971 F100 Long Flareside - 390/4spd - sold
1972 F100 XLT Ranger - 360/C6 - Gramp's old truck
Plus '53 CJ3B, '54 CJ3B, '67 CJ5, '70 Jeepster, '71 Jeepster
I'm running 235/70-15 roughly 1" shorter than yours.LA 66 wrote:I just measured mine. It's 38 3/4" to the bottom of the cowl. Mine's wearing 235/75-15's. What tires are you running?
I went outside and started rolling the truck back and forth earlier and noticed that the truck was kind of trying to ride up onto the outsides of the tires when rolled forward and going the opposite way rolling backward, so I got under the truck and did a little alignment job on the toe of the wheels. This made the tire get a lot flatter when roll it back or forward.
I've still got a camber issue but not as bad. The engine I've got in now (302 and c4) is probably a good bit lighter weight than the 400 and c6 that was in it. I'm thinking about cutting the top coil out of the spring. I'm just kind of scared that its going to drop too much and then I will need a new set of springs again. Looking back now I wish I would have ordered the 6 cyl springs. Do you guys think there will be any ill effect of not having the flat coil on top of the spring?
- ezernut9mm
i have coils in the past with no problems.
