Anyone done a 66 F250 8 lug disc brake conversion?
I was just kind of browsing through and it seems like it should be possible using oem replacement parts from a 1973-1979 F250. I seem lots of brake conversion pages but they are all primarily dealing with F100 and 5 lug stuff. I was just curious to see if someone had done it with an 8 lug and what all was necessary.
Bill W did a jam up job on his f250 check it out. He will probably send you a set of patterns if needed
http://fordtruk.com/forums/viewtopic.ph ... light=lugs
1961 F350 pick up
1962
1963
1964
1965
1966 F350 camper
1962
1963
1964
1965
1966 F350 camper
The 66 F250 is an easy disc brake swap if it came with the 12 X 2.5 front brakes (most I have worked on did have them). If you have the 12 X 2.5 brakes, all you have to do is get a set of F250 front discs from a 68-72 and they will bolt right on to your spindles. You do not have to even mess with front end alignment. On the F250 the disc brakes used the same spindle as drum brakes and it all bolts right on including the caliper and bracket. No need to reinvent the wheel, just swap brakes. Because an F250 has bolt on brakes, converting to discs is a pretty quick project. Hawkrod
I hope I didn't buy a trailer full nonusable parts, But I acqired the whole front end , ( guy torched the frame in half near the cab) of a 1973 f250. So I have everything. I guess thats the best way to grab it. I'm hoping I can just take the '73 twin I-beams and spindles and swap mine. If not???
Any body done it this way. I probably am not going to do it until much warmer weather. But I'll try to do a write up, if it works.
Unibodyguy1
thank yourwhistles wrote:Bill W did a jam up job on his f250 check it out. He will probably send you a set of patterns if needed
I miss my slicks
thank you very very much for the infoHawkrod wrote:The 66 F250 is an easy disc brake swap if it came with the 12 X 2.5 front brakes (most I have worked on did have them). If you have the 12 X 2.5 brakes, all you have to do is get a set of F250 front discs from a 68-72 and they will bolt right on to your spindles. You do not have to even mess with front end alignment. On the F250 the disc brakes used the same spindle as drum brakes and it all bolts right on including the caliper and bracket. No need to reinvent the wheel, just swap brakes. Because an F250 has bolt on brakes, converting to discs is a pretty quick project. Hawkrod
I miss my slicks
I did a swap on my 65 250.Used a 1976 (Ithink) donor.Swapped the I beams because of the kingpin sizes were different.Replaced all the bushings and tie rods and got it aligned.No problems.
Joe
Joe
1965 250 Camper Special
390,650 double pumper,headers,410 gears,saginaw power steering,front power disc brakes and pertrinix ignition.
You know I am not sure. I have read where people have used older wheels, provided that they were at least 16" wheels. I mean if you think about the massive drum that it is replacing it should not be a serious issue.Unibodyguy1 wrote:I saw this post and was wondering about the wheels, I suppose you also have to have the newer wheels for the righ backspacing??
Michael
- Blackwaterforge
When Jonas did the conversion on mine (he is the PO), he used the stock I-Beams and just used the spindles from a '71. He said he had to change the king pin bushings as well to a new size.
1991 Porsche 964 Cabriolet
2006 Cheby Silverado
Thanks for the pictures. I was actually thinking about the red and black color scheme for my truck, but opposite of yours. Black on the top and red on the bottom. The only thing I think I might need are the caliper brackets. I found some made by a1 cardone, but I am not certain if they are the correct brackets. I will most likely try them and see. Worst case, they don't fit and I have to make some.
- Blackwaterforge
F250's can have either size kingpin. It depends on the GVWR of tha truck. Regular F250's have the small kingpin and heavy duty ones have the big ones. Also note that most 73-79 larger applications like Super and Crew cabs will have the bigger kingpin automatically even if they have a low GVWR. HawkrodBlackwaterforge wrote:The kingpins on my truck were 7/8.
The king pins on the 73 were 1 1/16.
