Diesel discussion.
Diesel discussion.
I've watched several different ventures into putting a diesel into one of our trucks. Some were fanstastic and well done, but mostly I find the weight a problem. Since our frames really aren't made for this kind of weight in the half and three quarter tons, I been thinking smaller is better. Candidates run from Perkins to cummins to what I'm thinking might work best, the Mercedes diesel. As most of you know, I am a Ford motor in a Ford truck kind of guy, and don't like the thought of installing foreign engines in anything. I believe the engine is the heart of the vehicle. That being said, perhaps I should mention that I'm going for use, with this idea and cost is a factor. I want to be able to drive my truck accross country and get some fuel mileage and have pulling power if needed. Some of you may know, that Ford intended to come out with a smaller diesel in the half ton pickups but it has not happened. Not sure why but this is the case. Had hoped this would eventually solve my problem but not yet to be. What I hope to accomplish with this thread is to see where everyone stands in regard to opinions on which would be best suited for my diesel idea. So I have compiled a list of possibilities and what i think I want.
Smaller diesel engine with turbo.
Automatic tranny with overdrive if possible.
Disc brakes in front is neccesary for extras weight pulling and stoping.
Engines I have considered Cat, Isuzu, Perkins, 7.3 int., Cummins both 6 and 4, and Mercedes early and later like used in the Ram vans.
Do you know of other options and if Ford used anything other than cat , cummins , International, and perkins in their trucks?
Pro's and cons and anything interesting in the way of ideas.
You are over looking the diesel that Ford used in their mediun duty trucks in the 60's, the Dagenham diesel, it was a light weight diesel. It came in a couple of different sizes one of them being the 363 CI.
Michelle
international scouts used nissan diesels, some had turbo.
weight not a factor.
friend of mine has a mercedes 5 cyl diesel i could have but would need to find a way to mate up to a ford trans.
say no to the chebby/olds 6.2 diesels
My vote would be a 4bt cummins there are alot of parts for these as far as swap parts it ca be bolted up to almost any trans and very afordable. there are a few running around my area and are getting very very good mileage like 25 to 29mpgs.
www.4btswaps.com/
the weight of the 4bt is around the weight of a big block.
www.4btswaps.com/
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
BackyardRest
I plan on putting a new 6.7L diesel in my 66 Ranger. Along with a few 2011 F series upgrades like NAV, and SYNC.. Stock looking on the outside but 30mpg on the highway and a truck I can go anywhere with..
Thats if I can get it to AZ fairly cheap.. I may drop the 390GT engine in so It could be driven there.
tomrooster
A few years back I saw a web site where guys were taking diesel motors out of farm tractors and putting them in older trucks and were getting good mileage with them. I think it was yesterdays tractors. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
turbocharged and 145 HP....
sounds like an engine that would be a good Ford diesel conversion
Is the Dagenham British? I admire a lot of the British ideas, but working on British motorcycles has led me to believe their engineering good and electrical systems bad. Reading an 60's repair manual for the triumph left me with a hurting head. Loved the 69 Bonneville for riding though. I know nothing about the Dagenham engines. This doesn't mean I wouldn't consider one, but I do require a turbo setup for the extra power on a small engine. What years were the Dagenham engines used, and did some or all of these engines come with turbo?
As to choice of engines , I had considered the 5 cylinder Mercedes but most were not turbo engines if I remmember right, and why not use the Mercedes transmission along with the engine if going that way? There was a Nissan diesel on Craigslist with tranny in Kansas city but didn't say if it was a turbo. Somehow using the Nisan doesn't seem to feel right.
The 4Bt Cummins is a real contender but prices are just unreal for these engines. Mostly, I'm finding the asking price to be around 3K for one used. Doesn't make much sence when looking at the bigger Cummins at less than these prices. As to the 6.7 I would love to have one in one of my trucks, but it doesn't make much sence to spend 20K on an engine and pretend I'm going for economy. I've heard that used Frito Lay trucks with the 4bt engines can be bought for about 3K which would make more sence for a conversion if I could find one with a good drive train. Right now, I'm just kicking tires and shaking trees to see what falls out. The whole problem boils down to cost of getting my parts and trucks home. Nearly everything with a good body is out west and I'm in the rust belt in southern Illinois. I recently bought a new F250 and have had it less than three months and have 5500 miles on it. Need to keep mileage down on the trucks and frankly it only gets about 17mpg average overall. Not unhappy with the mileage but not ecstatic either. I think with a different tuner and elimination of the def junk it would do better but who knows. with it under waruantee, I'm not going to mess with it untill it is out. Hopefull several years from now.
To define what I'm trying for, I will say cost effective is uppermost here in my decision. This means cost of engine and conversion with good fuel mileage. I want something that is everyday drivable and can be done as cheaply as possible , with as few problems as possible. Truthfully an automatic transmission would be nice but these hurt fuel mileage. With this in mind the 6.7 is not for me.
Weight is another factor that needs to be considered. Our trucks have a rivited construction and flex. When it comews to the wieight of a diesel I believe this is an important consideration. Just how much I don't know. I won't be jumping the truck over any obstacles and it won't neccesarily be going off road, but then again I may have to drag something out of the woods. This means a posi rearend but I doubt I will try and go 4X4 since I don't have one in a slick.
fendermender
fire truck
Well if you want a ford diesel, the pickins are slim here in the states. You could get the Mexican built 6.7, but you'll need the trans and all the other crap that goes with it. It would be difficult to fit it in a slick and I would bet the mileage would be more like 18 than 30.
I wouldn't even consider ANY diesel made after 2007 with all the BS they have on them now the milage is crap.
I am a diesel addict and own several of them, but the new engine I want is the ecoboost from a new f150....
- Paul Merrell
Well stay away from the Isuzu expensive to repair the engine. If I where you I would look for the Frito Lay truck. I have worked on them a little looks like it would be a very easy swap. And they have a automatic and good power. But try to stay away from the emission ones it is a real pain. Just ask any trucker and mechanics in the shops.
- 6166 Junkyard Dog
here is one of the many reasons to stay away from the 6.0's @ 97000 miles
[albumimg]6147[/albumimg]
[albumimg]6146[/albumimg]
[albumimg]6145[/albumimg]
and also stay from these aftermarket air intake systems like K/N or Green it almost cost us a new motor with no warranty,, Oh yes will shove more air down it's throat with all the small dust particles it will not catch causing oil/sludge build up in the intake tubes etc.. that will shut the engine down and destroy it
Kathy
Now Cooper will try his best
RhodySlick'63
the nissan turbo diesel used in the international scouts is just a few HP less than the 223. mpg is in the high 30s.
personally i would be doing this if i had the funds
http://anchorage.craigslist.org/pts/2218833697.html
65TremecGT
Kind of off topic but still diesel related, I friend of mine just got his TDI Samurai up and running. Its a little offroader with VW TDI engine and toyota axles. He is getting 30mpg on 33" tires plus it will climb hills while offroading with no problem, so far he is very happy with the swap. What started with a $3500 project budget did turn into 10K but came out nicely! Still less than a yamaha rhino and its street legal to boot!
Interesting input, was hoping to stay away from the riceburners if possible. Seems they are the most efficient when it comes to fuel mileage though. Will be kicking this around for awhile, as it is in the back of my head to do this, but funds for such an undertaking are low at the moment. To many projects and to little time and money. The 4bt sounds like the most doable by buying a bread truck. Otherwise, it might be easier to do what others have done, and buy a whole truck and switch out the body. The just seems to be a little wrong, to do the body swap.
