Front clip removal....
Posted: February 28, 2011, 11:45 pm
by 63Longbow
Did a search for fender removal, what i'm lookin for is the process in removal of the front clip grill on back.
What started this i removed the rear axel replaced bearings, seals breaks breaklines and removed 3 of the 9 leafs along with the bushings. That went so well, i'm going to attack the front. Want to remove the grill inner and outter fender and work my way in......just how many bolts....and nuts are there, that hold that fender on?
1963 F100 223ci 4 on the floor T18 stepside Az. truck
Mark Mitchell
Posted: March 1, 2011, 1:05 am
by 61 Merc
Uncle Skip just recently did a posting about removing the front clip. It is in the hints and tricks section. This is the link to his post.
http://fordtruk.com/forums/viewtopic.php?t=19737
Hope you enjoy this proceedure, much easier pulling the whole clip then pulling it apart.
Dean
Posted: March 1, 2011, 11:39 am
yes much easier to remove the whole thing and then dismantle it on the floor/ground.
by foodstick
Step one of a first time front clip take down is ...scratch and cut and bruise your whole body ...and cry rust filled tears !
Just having fun, read the listing of Skips for real help.
I will guarantee that you will find yourself pacing the floor with a hammer in your hand, mumbling cuss words..at SOME POINT !
Posted: March 1, 2011, 12:57 pm
by HiBoy63
Also go to napa walmart or your favorite auto parts store and secure at least 4 cans of rust buster brand penatrating spray. The 4 cans is just a suggestion depending upon where you live within the continuous united states or canada or anywhere slicks are found.
Big help....
Posted: March 3, 2011, 1:45 pm
by 63Longbow
Thx. for the info. on removing the whole front, and a great write-up. Found all the bolts 3-4 of the hidden bolts came out need to cut ...grind, torch kept cuttin out ( no O2) torched the two big ones in the front, just need to pop the bumper off tonight, should be off Sat. morning.
Thx again,
Mark
