'90 seat in a '65 cab
Posted: March 3, 2011, 12:57 am
by rctcomp
Got a free seat from a 1990 super cab. so...
First I tried to use the brackets from the old seat but the slide release mechanism interfered with the bottom of the seat rail.
Plan B.
I cut a chunk out of the front part of the bracket. Pounded it flat and welded it back together.
Hopefully you're a better welder than I am.
The modified bracket lined up perfectly with the existing holes.
Not sure if I like it or not. The seat is kinda high, not much room between me and the steering wheel. I'll try it for awhile, worse case I'll get the old seat reupholstered and swap em again.
Posted: March 3, 2011, 7:35 am
by Hookedtrout
Free is good, gives you those options to try and abandon if you don't like. Thanks for sharing, it may help those of us that come across the same seat.
Posted: March 3, 2011, 9:35 am
by slickmainer
i recall someone saying that the old seat tracks will swap on tho the new seat and bolt to the original floor holes with out modification. Some washers were needed but they didn't say where to put them.
Posted: March 3, 2011, 9:55 am
the trick here is to use the 61-64 seat brackets that have the adjustment lever at the front.
a discovery i made after i was done painting a set of side lever brackets and went to install them on the seat.
you will also have an issue with the seat back locking mechanism hitting the gas tank. easily removed. no need for a locking seat back, the original did not have it.
Seat
Posted: March 3, 2011, 6:29 pm
by William-in-St George
Nice bit of engineering that cut/pound/weld. Sometimes the simplest answer is right in front of us.
Posted: March 3, 2011, 7:23 pm
by Power by Ford
I did mine the exact same way and it works great. I also cut a piece of 14 ga to shape of the seat bracket and plated the outside to clean it up some.
Posted: March 3, 2011, 11:04 pm
by slickmainer
ICEMAN6166 wrote:the trick here is to use the 61-64 seat brackets that have the adjustment lever at the front.
i haven't even paid attention, but are the 65 and 66 on the side then?
