Anyone know what the original speedometer tooth gear count would have been for a Slick with a 3.25 rear?
I put a C-6 in it, and then changed rear gears around so I forgot what it would have been originally.
Speedometer Gear Tooth Count?
- banjopicker66
- Uncle Skip
oldfordcoupe
- banjopicker66
Thank you gentlemen! It turns out, Skipper, that I had a 17 tooth gear in there already. Even with that, though, with the 2.75, the speedometer was reading 50 when I was doing 60.
OldFord, I put a 19 toothed gear in there per your suggestion, and it is giving me very close results. I show 36 MPH when doing 35 actual, and 47 at 45 actual.
I think the differences between the different recommendations as to which gear count to use have to do with the drive gear count on the transmission output shaft.
Thanks again.
Thanks again.
