66 f100 wheels and tires
Posted: April 27, 2007, 11:16 am
by tmallisnyc
does anyone know the factory wheels and tires the 66 f100 long bed came with?
thanks
tm
Posted: April 27, 2007, 11:18 am
by Johnny Canuck
"Outies".. 5 on 5.5" bolt pattern ford pickup wheels used from mid '65- mid 80's i believe.
I have a set of 4 (I think) in my back yard, where are you?
Posted: April 27, 2007, 11:58 am
by tmallisnyc
i am in nyc area/tri state where are you do you have a photo?
Posted: April 27, 2007, 12:44 pm
by Johnny Canuck
Not close enough to justify shipping. check your local yards, they are common as houseflys
Posted: April 27, 2007, 1:34 pm
by Garbz
Any 66 to 72 stock ford truck wheel will be correct for drum drum brakes. I have also seen on stock trucks some 16" 5 on 5.5" wheels too, pilfered from F100 four wheel drives.
If you have discs then the reliefed wheels will be needed. 72 to 96.
Common as fleas as JC says.
The truck will also use the spinner bar type poverty hub cap in white, silver or stainless for a standard cab or a full face type being reproduced by Dennis Carpenter for a custom cab.
Garbz
Posted: April 27, 2007, 1:37 pm
Johnny Canuck wrote:Not close enough to justify shipping. check your local yards, they are common as houseflys
But withone difference JC the original early style wheels won't work with disc brakes and are slightly different in the rim section, you can tell the difference e if you put then side by side.
Posted: April 27, 2007, 7:41 pm
by mwilk1
mine had 16inch on 5x5.5 but like the guys said if your going to use disk brakes you cant use original wheels. YOu need later models for that. Mike
