Question for the twin I-beam experts
A couple weeks ago, I spent some time with the wire brush cleaning all of the front suspension parts prepping them for painting.
This last weekend, as I was laying out some of the smaller pieces on a piece of plywood to paint, I noticed that I had an odd number of parts lined up to paint.
When I started checking, it looked like I was missing one of the spacers that mounts below the lower spring perch on the I-beams.
This spacer is approximately 5" long X 1.5" wide X 1/4" thick, with an approx. 1" hole near one end.
I searched all around the garage, under the truck, under the other car, everywhere, and now I cannot find it.
Was I just imagining that I cleaned up two of these pieces, or did my slick only come with one?
I talked to Bill W. about this, and to his recollection, two of his slicks only had one of these spacers.
Also, if I only had one to begin with, does it matter which side the one goes on?
Finally, to really confuse myself, in looking at the blow-up illustration of the front suspension, it shows one of these spacers on both sides.
I need help from the experts here.
Thank you!
Thank you!
Steve F
1965 Mustang Coupe
1966 F-100 Shortbed CC/Ranger
2010 Mustang GT Convertible
2010 Shelby GT500 Convertible
1965 Mustang Coupe
Spring spacers
On 3 trucks I have discovered one spacer on each side of one truck and the other 2 trucks had one spacer on the drivers side only (maybe to compensate for the weight of the driver?). All 3 trucks were 1965 models.
- Uncle Skip
Never heard of a spacer.
Could he be talking about the metal cup that fits inside the spring and holds the bottom of the spring in place on the I-beam?
Pictures would really help us not stagger around in the dark like a bunch of drunks.....
Meanwhile, back at the ranch, I'm going to go get myself another adult beverage.
U@ss
U@ss
Pictures of the lower spring perch (or "cup") and
Here are some pictures, first the two pieces side by side, then with the spring perch or "cup" sitting on top of the spacer
Then for more confusion, I now remember that this spacer was on the passenger side of the truck (I think)...
Steve F
1965 Mustang Coupe
1965 Mustang Coupe
- ezernut9mm
i wondered what the lip in the cup was for as my 66 had cups like that, but no spacers. interesting.
- Alan Mclennan
I seem to remember there only being one on each truck, I wonder if it is there to compensate for the camber in the road.
Something you may not be aware of is that one spring is taller than the other on the twin I beam trucks. I have 3 NOs spacers as een in the picture, and I believe these were used in front end Alignement but have never actually checked. I have some reason to believe this but forget what or where I ran accross this information. Some of you may have seen aftermarket shims for springs that screwed into the spring and were made out of aluminum to raise spring height. I think ford used these pieces for the same reason. Anyway, make sure you use the taller spring on the drivers side of yoru truck. I believe this was to compensate for the drivers weight on that side of the truck.
- FORDification
Keith
FORDification.info | FORDification.com | FORDification.net
Also own: '67 F100 2WD SWB - '68 F100 SWB 4WD choptop - '75 F250 Ranger XLT Supercab Camper Special
- Alan Mclennan
Bugger!, who would of thought of that!, thanks Keith!FORDification wrote:http://www.fordification.com/tsb/viewto ... =653&p=677
Well, thanks for all the info, especially the link to Fordification with the explanation for the use of the shim.
Also, I finally found pictures of my tear down of the front suspension, and in those I see I only had one of these shims, on the passenger side of the truck.
Mystery Solved!!!
Mystery Solved!!!
Steve F
1965 Mustang Coupe
1965 Mustang Coupe
Only one shim - can't remember which side
OK, you guys got me curious.
I went out to the barn last night and pulled apart a set of late 60's/maybe 70's I-beams with disc brakes. I had bought these from someone who changed his mind about upgrading his slick to discs.
He had torched these loose from the donor truck - still had the cabmount/cast beam rings and rubber spacers still attached to the radius arms, and a chunk of the coil spring was still trapped in each cup. Must have been in a hurry or all he had was a gaswrench.
Anyhow, when I broke down the assembly and separated the radius arms from the I beams I had two cups but only found one spacer. Can't remember which side it came from though. Old age will do that to you.
Just like in Steve's picture, just not as clean and shiny.
Doug
Doug
