I'm really thinking I want to take my T5 out and put in an automatic. Just curious if anyone knows if they are about the same length so I wont have to mess with shortening or getting another drive shaft. All input is appreciated
Shane
T5 swap out
unibodynewbie
unibodynewbie
unibodynewbie
Fox Mustangs used different length drive shafts for AODs and T5s. That said, if you go with an AOD you are probably going to need a different shaft. I do not know which one was longer, the AOD or T5.
When we put T5s into early Mustangs, we have to shorten the shaft about 3/4" if that tells you anything. (Like if it came with a C4 and we put in a T5, had to cut 3/4" off the shaft)
I guess that means a C-4 is 3/4" shorter than a T5!
TxSlick66
aka MustangSteve
Money you ENJOY wasting is NOT wasted money...
aka MustangSteve
Different years of T-5s have different Input shafts.
http://www.allfordmustangs.com/Detailed/349.shtml
