64 f100 power brake booster and pedal HELP
Posted: October 24, 2011, 5:46 pm
by Tigger!
Help!
I have a 64 f100 project that i have dropped a 460 into and need to move the power brake booster over and either keep the pedal where its or move it.
Has anybody out there done this swap or had to move the booster? I need ideas/help ( preferably with pics)
Thanks in advance for all your help![/url]
Posted: October 24, 2011, 6:34 pm
by unibody madness
Tiger
I do have a 460 in the 61 lwb, and had no problem putting in a vac assist.
I never did put a dual chamber master in it but that would not be a problem either.
I got my assist out of a jeep cherokee at the local pic and pull and it fit fine. Maybe yours is too large? as far as install, I pulled the master, placed and drilled for the assist, and adjusted the shaft between the assist and the master... about three hours total
Posted: October 24, 2011, 8:19 pm
by MadMaxetc
Did you use the stock towers from a 73-79? If you did you need a 7" or 8" booster. The Larger 11" will not fit.
Posted: October 24, 2011, 8:32 pm
by 62galxe
on my 78 booster the bracket raises the booster up if i remember correctly. it was in a 460 truck.
Posted: October 24, 2011, 9:03 pm
by MadMaxetc
62galxe wrote:on my 78 booster the bracket raises the booster up if i remember correctly. it was in a 460 truck.
Cporrect. If you use the bracket it will do that and move it out to clear the cowling.
Posted: October 24, 2011, 9:34 pm
by Tigger!
Thanks for the advice, but I'm using an 06 crown vic. Setup and have to move it over to the right which means everthing else has to be modified. Theres no way it will fit were the old one was at.
Posted: October 24, 2011, 9:59 pm
by MadMaxetc
Ahh. We happy fabbing then. Don't think you will find anything that will fit
Posted: October 24, 2011, 10:26 pm
by Tigger!
Yes I know. That's what I was scared off!
Posted: October 24, 2011, 11:04 pm
by MadMaxetc
Don't be scared...metal can sence fear.
Posted: October 24, 2011, 11:06 pm
by Tigger!
Lol!!!
Posted: October 25, 2011, 8:59 am
by sully5
I moved my booster left to the hole that would be for a hydraulic clutch (at least I think thats what the hole was for). there was a punch out the same size as my original brake hole. Required a litte fabbing, but not much.
I am running an AOD, so losing the clutch pedal was no biggie. I moved the brake pedal to the clutch side and reversed the peda so that it turns toward the gas pedal instead of away from it. I also made the pedal bigger, more like a late model disk brake pedal.
One other thing you can do, if you are running one of the small aftermarket boosters, is eliminate the bracket altogether and bolt the booster directly to the firewall. The aftemarket boosters have 4 studs that usually line ip with the braces inside the firewall.
Just some ideas. It all depends on how far you are willing to stray from stock and fab up or modify parts.
I stopped being skeered of fabrication back in my drag racing days, so there aren't many mods I won't jump into.
