removing/repairing front cab mounts
Posted: December 10, 2011, 11:17 pm
by Shenanigans
Ok so Hi everyone :hello: I just wanted to introduce myself on here, truck talk, as well as on projects and builds. My name is Matt I'm 22 and working on a 61 flareside. Here is the link for my build where I will post most of my pics. http://fordtruk.com/forums/viewtopic.php?t=24281 So to bring everyone up to speed`, at the moment I am working on the cancer I found on the driver side front body mount. I'm attempting to drill out the tack welds to get under it but it is not going as smoothly as I hoped here are some pics.
If any one has any advise it would be greatly appreciated or if there is any questions don't hesitate to ask; cant wait to get to know you guys
Posted: December 10, 2011, 11:31 pm
by Bill W
drill bits are okay, but you should get a spot weld cutter for that job.
Posted: December 11, 2011, 1:47 am
by jamesdfo
Matt: This might be one instance where it would be easier to drill them all the way through....then, you can plug weld the new mount on from the top....and as an added bonus, you won't have to be laying underneath the truck to weld, or grind the welds. If done properly, a quick touchup with a disc to knock the top off your rosettes after welding should be all that's needed. (I'm assuming you have mostly gutted the interior?)
James
Posted: December 11, 2011, 1:58 am
by oldtrucks
Shenanigans
Looks like you are on the right track the suggestion to drill all the way through is good for the floorboard area but not for the area on the side. I have cut away everything but the flanges where the spot welds are. Makes it a lot easier to locate the spot welds and get them removed.
And welcome from the wilds of Northern Idaho.
Posted: December 11, 2011, 9:25 am
by unibody madness
Matt,
Glad you finally decided to join. I told you these guys would be a great help.
The suggestion to drill all the way through is exactly right. I had not thought about the new mount not being drilled, so that ends my worry about filling a through hole. then cutting away ththe rest except the side flanges answers your concerns about that.
Guess I am not the only Houdini....
Posted: December 11, 2011, 9:46 am
by jamesdfo
Damn Mike, you are TOTALLY correct on that....I was looking at this near midnight last night, and with the pic size, on my monitor I couldn't even see the outside end that goes to the back of the sills
James
oldtrucks wrote:Shenanigans
Posted: December 11, 2011, 2:47 pm
by oldtrucks
jamesdfo
Well I have to admit I've been down this road a few times. I do things most of the time without having to think about how to do it because I've done it so many times so when this post came up, thanks to Shenanigans, it got me to thinking that I am headed into this exact process on Rob's 63 UNI.
I will begin to document the process of installing the cab mounts pretty soon. They are already removed so I will only be able to show the install.
Looks good
Posted: December 11, 2011, 3:12 pm
by William-in-St George
Looks like a real rust free truck. Lots of undercoat. I'd get a spot weld cutter from eastwood and continue as planned.
Posted: December 11, 2011, 5:22 pm
by rickairmedic
I agree with drilling through on the floor side on the sides though a spot weld bit would work well and Harbor freight actually sells them I have picked up a few at my local store . I would bet its the same basic cutter Eastwood sells but at a third the price .
