Gas mileage improvements
Posted: June 4, 2007, 6:34 pm
by donald luster
As the gas prices keep going up and up. If anyone has any tips that you have tried and worked for better fuel mileage please list them and what engine etc. If anything didn't work please tell about it also. Thanks because I sure getting tired of being ripped off by the oil Industry.
Posted: June 5, 2007, 8:29 pm
by donald luster
my vehicle is 223 6cyl with 389 gears in rear with 3 on tree. The reason for posting that was to try and get a discussion relating to mileage and mayby help all of us. thanks for your comments. Hope other with try and keep this going for a good long informative time. Thanks Don
Posted: June 5, 2007, 9:00 pm
by mwilk1
my 64 has 223 3spd and 392 gears. as for mileage i have no clue. Hadnt even tried to figure it out yet.
Posted: June 6, 2007, 11:33 pm
by ivaf100
Try a clutch fan or electric fan. I put a clutch fan on my 390 and I could tell a difference. I never actually checked the mileage, but it was a noticeable improvement.
Posted: June 6, 2007, 11:40 pm
by MadMaxetc
Get one of these and put an S-10 T5 behind it. The S-10 T5 is only good to 240ft-lbs, but the 223 is not going to have that. There might be more to the swap, but it is a thought. It would get you an OD gear and you would be able to keep the engine at lower RPM.
Doc Pepper is right on. I am doing a 300/T5 (mustang) combo and hope to get 20+ (It is NOT a stock 300 :wink: )
Posted: June 7, 2007, 3:01 am
by ripsnorter
dang max, if only those things werent $160 I'd be tempted to try and stuff one of my S10 trannys in there.
mileage?
Posted: June 7, 2007, 8:44 am
by Texas Monty
My 262-6 - with the 4.10 rear end gets 9-10 mpg. One thing that bothers me is not so much that the mileage is bad - but that the gas isn't getting burned. the exhaust is extremely rich, the carbon buildup is pretty awesome. I have messed with the carb about all I can - not that there is much you can do with a rebuilt one bbl. The idle screw and the float.
I am going to eventually go with a different rear end ratio.
Posted: June 7, 2007, 10:15 am
by kid2
My stock 300 Six with the stock 3 speed trans and a 3.25 rear gear on 15in rubber got about 15mpg going to Pa last Year. i am planning on putting in a 2.75 rear gear to go to Minnesota in a couple of Weeks to see if it gets any better..............kid
Posted: June 10, 2007, 6:04 pm
by FRDSTRODER
I,m thinking of changing the 390 c6 set up that I have in my 66 to a 89 crown vic 302,aod with stock fi.I,m sure it would help my mpg but I don't know how much . I know a lot of you have made this swap . what kind of mi. could I expect.
Posted: June 11, 2007, 11:07 am
by donald luster
Thanks for posting the adapotor web page. This was very interesting. Don
