63 frame swap
Posted: January 15, 2012, 9:44 pm
by appel400
Can someone tell me what years of crown Vic or grand marquis I can use for the frame swap ( will the 90's and up work ) and what would be the best to use
[ Post made via iPad ]
Re: 63 frame swap
Posted: January 17, 2012, 12:07 am
by William-in-St George
Do a search here for crown vic frame swap. Many have done this with varying degrees of success. Check with the moderator.
Re: 63 frame swap
Posted: January 17, 2012, 7:56 am
by appel400
William,
Thanks for the great advice, I am new to the site and just can't get off of it , all the knowledge just amazes me.
Can't wait to start my project just trying to finger out the best way to proceed
Thanks again
Re: 63 frame swap
Posted: January 18, 2012, 8:55 am
by slickmainer
for some reason I thought it was 03-08, maybe 07?
Re: 63 frame swap
Posted: January 18, 2012, 12:37 pm
by ezernut9mm
03 and up had a bolt in aluminum x member. they are an easy way to get ifs, big disc breaks and some lowering.
people have used the whole frame from earlier cars, but requires a bunch more fab work.
[ Post made via Mobile Device ]
Re: 63 frame swap
Posted: January 18, 2012, 1:24 pm
by appel400
Thanks guys,
If i go with the aluminum X member from 03 and newer, what can i use for a rear end that will match
I have read some stories on the site but if you know of one that will help please pass it on
I am also having problems uploading pics of the truck
Re: 63 frame swap
Posted: January 19, 2012, 11:27 pm
by Toyz
The T-bird/ Mark VIII IRS is a fairly easy swap with swap plates available if you don't wish to fabricate your own. Either will require a switch to Cobra hubs and rotors if you wish to retain common wheel mounting patterns (the factory offsets are not the same, so aftermarket wheels are often utilized). The Cobra changeover would allow a common spare with the 4.5 inch, 5 lug pattern. The Panther (03 up) chassis utilizes this pattern, but with the "front wheel drive" style offsets; the Mark and Bird are a different pattern. The police package suspension is often recommended and is readily found, but stiffens up the ride a little and may not be preferred for an extremely low stance. The slightly wider track seems to be more noticable on the lowered vehicles.
If you choose to obtain one from a "pull-it-yourself" yard, you may want to invest in a cordless impact and a good selection of large metric sockets.
I wish I could provide pictures but my Panther conversion is now relegated to following two other IFS Slick conversions. I am considering using it in a heavier duty Slick due to the robust components and wider track.
