Page 1 of 2
Sorry for this nothing post but..PICS!!!..A few more added
Posted: June 13, 2007, 12:18 pm
by Phil
My 62 Uni will be here within the next few hours and so far I am completely useless at work. The driver said he was in Indiana at 8am and was stopping 1st in Flatrock MI. 40 min north of me. I am hoping to see it before 5pm.
I am really stoked!!!
Look for pics tonight assuming it comes before dark.
Re: Sorry for this nothing post but
Posted: June 13, 2007, 1:42 pm
by Slick Fan
Heavyhauler wrote:My 62 Uni will be here within the next few hours and so far I am completely useless at work.
I don't blame you, I probably would be too.
Posted: June 13, 2007, 1:45 pm
by kid2
not a problem, we understand completely. post some pics as soon as you can...............Kid
Posted: June 13, 2007, 2:55 pm
Lol, reminds me of the day I was waiting to see if I won the auction on my 85 GT. The auction was due to end 3 hours after I got to work. Didn't dare get near a computer there because it was very slow Saturday AM on the lot (it was like 18 degrees out and windy - go figure) so there was a lot of drama from the managers. I basically hid between my office and the smoking area outside the back door til 11:05 AM. I called the seller long distance after the auction end so I could ask him if I was the winning bidder, he responded with "Congradulations you just bought yourself a real nice car". Shoulda just called in sick for all the good I was, lol.
Posted: June 13, 2007, 6:46 pm
by Phil
Posted: June 13, 2007, 6:51 pm
by Phil
So far its like dating the prom queen but she has a lot of baggage.
Overall I am happy so far. Engine has lots of power and it shifts good but it idles horrible. The ride is so bad and the steering clunks so much I'd be afraid to see how fast it is.
Its like how it must have been to ride the stage coach.
Pass side fender is loose at the bottom where the bolt pulled free. It rattles fiercly. In fact it all rattles. It is so beautiful though. Guess we'll see what the future holds
Posted: June 13, 2007, 7:02 pm
Having bought several slicks - that's a nice truck! The "hanging thingys" look like 60s era traction bar mounts if memory serves me. The tires & wheels look right at home on it too. Mine was worse (rocker rust too) had er welded back up in couple weeks. Check my album pics for ideas if you don't want wait on patch panels.
Posted: June 13, 2007, 7:06 pm
Heavyhauler wrote:So far its like dating the prom queen but she has a lot of baggage.
by Paul Merrell
Looks like you have some overload springs and it looks like it may had some traction bars
Posted: June 13, 2007, 7:51 pm
by Slick Fan
Yep, traction bars. Judging from the size of overload springs & waves in the bed floor, that baby's hauled some WEIGHT in it's day.
Still, it looks like a great little truck, I'd love to own it!
Posted: June 13, 2007, 8:49 pm
by Phil
Man I am generating questions by the minute.
The PO used a Painful wiring system. spliced, hacked and thousands
of butt connectors
Its going to take me days to figure out whats wired where.
We are going to have a rust discussion soon. I need ideas on deterring and repair. Ohio is hell on metal.
The single resivoir master cylinder is going to keep me up at night.
Ill need a great swap page. I may swap the MC then later do a disk swap.
Next up, seat belts. What did you guys do? I used wesco 3 point belts in my Fairlane. Saved my life in my crash. Yeah, Ill do that again. No idea where to attach yet though.
I want to pull the rear bumper. I love the rolled pan look. Unfortunatly its the only nod to safety on the whole truck.
The engine refuses to idle well.
Its a reman AutoZone holley 3310 Mystery CFM
Compression test, vac test and timing checks tomorrow
The tie rod ends roll front to back when my buddy turns the wheel. No idea if thats normal.
This thing have kingpins? How do you know if they are bad.
I have a terrible binding clunk when turning on the outboard wheel on both sides. No idea what that is. Sounds like the wheels hitting the fenders. They're not.
Posted: June 13, 2007, 10:59 pm
Save yourself a few bucks and just call Custom Performance Products and order the brackets for disc swap $95 for our trucks. I just went through this dilemma with my 62 Uni, because of the common parts used in the upgrade it's actually a few bucks cheaper to go with the disc swap because the 61 - 63 drums are pretty pricey and they don't give the front wheel cylinders away either. I used a 68 Stang master cylinder for this truck (I used a 70 F 100 on the last one I converted), my brake pedal had 2 holes for mounting the pushrod bolt and by useing the other one it was a bolt in. The Stang brake pushrod because of the "flat" on it will allow you to use the brake light switch from the same car to eliminate the pressure switch also. Yes it does have king pins, probably not be a bad idea to do them while it's apart, the brake swap brackets will take about 2 weeks to get to you anyway. I just went through alot of stuff your looking at doing so if I can be of any help let me know. I can take more pics if you need them while I do mine also, I was thinking about taking them and posting it in the "Hints" section as a step by step anyway.
Posted: June 13, 2007, 11:37 pm
by Phil
Posted: June 14, 2007, 5:28 am
by jakdad
I see your helper is already seeing what needs to be done. This will be a great experience for that young man. Take it from me, you wont make a track he doesn't step in. And some of your neighbors will be like mine and say "Look, that nut down the street has drug up another junker".
That's only 'cause anything over 10 years old is a "junker".
Good luck.
Posted: June 14, 2007, 6:37 am
by DV65CustomCab
Step rust, big deal.
Rotten tailgate...normal.
The rear bumper ain't original, so I'd dump it too. Looks really out of place.
Rest of the truck is looking very solid. Good for you.
You can check the kingpins for play. With the wheel off the ground and the bearings adjusted properly grab the wheel at 12 and 6 and see if you can get any movement between the knuckle and the axle beam. If there's no slop, don't fret about them. They are made of tough stuff. Unless they were rarely greased and got lots of crud in them they hopefully didn't wear. Do the test BEFORE you greas 'em up as the grease may help mask any slop.
Posted: June 14, 2007, 7:45 am
by Phil
DV65CustomCab wrote:Step rust, big deal.
As in "huge hassle" or "pshaw, don't sweat it"
Posted: June 14, 2007, 8:38 am
by Johnny Canuck
What a teriible truck. I think you should send it directly to me for disposal, do not pass go.
but seriously
The hanging things are emergency brake cables. looks like you have ANOTHER uni with overload springs (why? on a short uni?) and Dwight is right the steps are a lot of cutting/welding but having seen your Torino skills I think you can do'er
The big clunk when you turn could be many things but the most likely ones are shot tie-rods or shot spring bushings (front or rear). Looks like an electronic fuel pump under there, might have something to do with your idle.
If the bottoms of those doors are as bad as they look, you might get yourself on the hunt for some better doors.
The tailgate.. might as well get a new one from Dennis Carpenter, those things are a LOT of work.
Both bumpers on your truck are from something else, but the front one looks OK.
Have fun!!! nice looking truck!
Posted: June 14, 2007, 9:39 am
My brackets are due here any day (actually a couple days late now). I'll take alot of pics while I am doing the swap so I can post them. Don't think other than rusty bolts it'll be tough anyway. JC made a point I forgot last nite, spring bushings. Does the truck seem to slip the wrong way right after you turn the wheel when you're driving, spring bushings. Every original straight axle truck I have run across needs them. Good excuse to have a reverse eye main leaf made while you are at it. A local spring shop quoted me $100 each to make the new main leafs, pretty cheap to lose 3 or so inches out of the front.
Feel free to PM me with any ?s, or just post. I'll PM you my email too. your rocker/step section doesn't look to be as rusted as mine was so should be a tad easier to fix. You can get the lower sill patches from Carolina Classics. Another set of doors is the easy way to fix them but if you can't find them there are patch panels out there to repair them.
Posted: June 14, 2007, 10:35 am
by Slick Fan
Regardless of it's little problems, that's still a mighty fine lookin' truck.
Out of curiosity, how much was the freight to get that little beauty home?
Posted: June 14, 2007, 10:56 am
Lol, like to new signature banner. That truck has a real nice stance!
