So I called up the machine shop and to redo the heads it $200 bucks not bad heck of a lot cheaper than a new one. The kicker is those broken bolts. The shop charges $30-50 per bolt for removable. Great I have 4 already and still haven't done the other side. Now the cost is close to the cheaper alum heads so I might as well spend a little more and get the performance heads instead of the stock ones.
The motor is a 95 - 5.8L - EFI - Roller engine - SBF. I have found two heads but since it has been so long I really need help in getting a decent head.
1st one if from ebay. it doesn't look bad and looks complete.
http://www.ebay.com/itm/230706015012?ss ... 1423.l2649
2nd one I found is:
http://www.speedwaymotors.com/flo-tek-s ... 46332.html
What are your thoughts on the above heads?
Do you know of any other options out there?
Looking for advice and information. I rather not have to buy a new set of rockers (roller), I would prefer to use the stock ones I have. I also don't want to buy new headers and would like to keep the existing manifolds. It not like this engine will be racing on the track.
