Adatives
1965 stepside
Adatives
Post by 1965 stepside »
Hv a 1965 stepside with a 1968 302ci what adatives
If any do I need or should I use to help protect
My motor?
Re: Adatives
I would recommend just using good quality lubricants myself for normal driving.
Now if you drive it hard I would consider a higher zinc oil, and a valve seat lubricant of some type in the fuel unless your heads have upgraded with hardened seats.
If you want to use additives for peace of mind I would recommend Lucas products,
they seem to work well, are commonly available, and are reasonably priced.
Welcome to Slick 60s.
cooter
Re: Adatives
Post by cooter »
a bottle of lucas with every oil change will keep that motor happy for years.
1965 stepside
Re: Adatives
Ok then great advice sounds like I will invest
In some Lucas. Do they make a gas adative also
cooter
Re: Adatives
Post by cooter »
they make everything, as long as it comes in a bottle (except booze)
62galxe
Re: Adatives
Post by 62galxe »
I use ZDDPLUS in my oil.
http://zddplus.com/
1963 uni PATINA BLUE
1965 short bed
hvlp1
Re: Adatives
Post by hvlp1 »
There is only one additive I have been sold on 100% to used in oil , fuel, and rear ends. I've tried everything listed here and more because I wanted to know if anything can compete with the miraculous outcome of Petrons Formula 7. Unbelievable the increase of power just from a pint of Petron is in the oil. Nothing touches this stuff hands down. Automatic transmissions on the otherhand is happier with Lucas, I've cured transmission slippage with Lucas & power steering whinning. Petron has to be purchased from a Petron dealer because it's not in stores. Go to Petron Formula 7 web site and call for the closest dealer, you won't be sorry.
1965 stepside
Re: Adatives
Thanks for. All the advice my 65 will be a very happytruck
Uncle Skip
Re: Adatives
Post by Uncle Skip »
Jason, use Shell Rotella T. It still has the zinc in it that you need to protect the cam and lifters. And Kenny is right on with the ZDPlus. Royal Purple makes a similar product and they're here i Houston.
Actually, there are several good gas additives for dealing with the alcohol problem, but be sure to use it every time. That crap ethanol blended stuff goes south very fast......
banjopicker66
Re: Adatives
Post by banjopicker66 »
One additional process that isn't often mentioned is to sample your oil's quality. It costs about $35 to have your oil sampled, but it gives you a total rundown of all the elements in your oil.
This gives you a good idea of the wear going on in the engine, and the properties of the oil can tell you if you can extend the oil change intervals, or if antifreeze and/or fuel are in it as contaminants.
One of the major differences in diesel vs otto oils is the TBN number. It was interesting to me to learn that diesel oils can be used for many more miles in a gas engine and provide superior protection at about the same or lower cost overall.
From Blackstone's website:
What is a TBN, and who uses it? In short, a TBN (total base number) measures the amount of active additive left in a sample of oil. The TBN is useful for people who want to extend their oil usage far beyond the normal range.
By comparing the TBN of a used oil to the TBN of the same oil in virgin condition, the user can determine how much reserve additive the oil has left to neutralize acids. The lower the TBN reading, the less active additive the oil has left.
An oil's function is to lubricate, clean, and cool the engine. Additives are added to the oil to enhance those functions. The TBN will start out reading in the 6.0 to 14.0 range (depending on whether the oil is for gas or diesel engines). When you first start using the oil the TBN tends to drop sharply. Then it levels out and drops more slowly after that. A low TBN test result, meaning very little additive is left, is down around 1.0 or lower.
Scientifically speaking, the TBN is one of two "neutralization number" tests run on oils. The TAN (total acid number), which is used for hydraulic oils, is the other. The TBN measures the total basedity of an engine oil; that is, how much base (as in, a base vs. an acid) additive is in the oil to offset the deleterious effects of acids coming into the oil from combustion and other sources.
However, the TBN is not the only factor to consider when determining how long an oil can be used. If wear accumulations and insolubles in the oil build up and become abrasive, we would recommend changing out the oil, no matter how high the TBN reading."
(end snip)
If you plan to use the truck for light duty daily driving with basic oils, $35 is a lot and probably not worth it. But, if you are using a high quality oil such as Rotella T, and you learn you can safely go up to 15K or even 20K miles on an oil change, it can be well worth it.
I recommend Blackstone Labs, as they are the only ones that will send you the sampling bottle and shipping tube kit for free.
Suggested reading: http://www.blackstone-labs.com/do-i-need-a-tbn.php
