4.6 DOHC is now running
kstones63
Post by kstones63 »
I have the truck back together and running. The fenders and hood are back on. I took it out last weekend and last night to a small car show and got a lot of good response to it. I still had several people that had no idea what the engine was. The truck really runs good and sounds good. I can't wait until I get a few miles on the engine so I can hit throttle hard and see what it does. :)
Here is a pic of the engine complete.
That engine looks right at home in there.
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
Re: 4.6 DOHC is now running
Post by Gritsngumbo »
Very Very Nice!
Kevin: I'm sure you're aware of the old Ardun OHV conversions for Flatheads (actually I believe they are currently making an improved version).
http://www.ardun.com/index.html
Think I'd have to fab some Ardun lettering and really blow the questioners minds :-)
Adrun OHC.jpg (57.69 KiB) Viewed 1874 times
1965fordf100
Post by 1965fordf100 »
Badass!
Phil
kstones63
Post by kstones63 »
I have thought about painting "kstones63" on the COP covers or the next thought is to get the Ford Raing COP covers. I definately want to get the Ford oil cap and dipstick. The main thing that I need to now is to get the chip so I can get rid of the codes. I finally disconnected the check engine light so I don't have to look at it.
I drove it some today and I think that I might be in need of doing a rear gear change. It will run over 40 mph in first gear at 5500 rpm and I backed out of it to let it shift. I am now at 3:23 gears so maybe 3:73.
It runs down the freeway at 70 mph turning just under 2000 rpm.
Kevin
kstones63
63 F100
Kevin,
Where did you find your radiator filler/ overflow tank? I have an inline filler cap, but would like to utilize a less bulky, prettier tank, and yours certainly appears to meet those qualifications!.
Thanks,
Harper
Post by Harper »
ok i may be missing something but where is your brake booster? :|
kstones63
Post by kstones63 »
Toyz wrote:Kevin,
Thanks,
Paul, The reservoir next to the head is the P/S reservoir. My overflow tank is mounted next to the radiator. I fill mine with the regular radiator cap. My radiator cap is higher thatn the engine so I don't need the to use a fill tank.
Harper wrote:ok i may be missing something but where is your brake booster? :|
The brake booster and master cylinder are mounted under the floor. The remote reservoir is mounted in the bed of the truck. I wanted to clean off the firewall and besides that those big heads would be in the way of the master cylinder.
Kevin
kstones63
63 F100
TXSlick
Post by TXSlick »
You certainly have done alot of very nice work there. I can appreciate all too well what is required to get something looking like that! Nice job!
DM66FE482
Post by DM66FE482 »
Kevin,
That engine looks great. I wished that I had gone that way with my 66'. A good friend of mine wanted to sell me a complete Lincoln which had been wrecked in the rear with a 4.6 DOHC and O/D transmission all for $500. I was convinced that I wanted an FE, well lots of dollars later I have what I thought I wanted. A 482" FE 296 deg .600" roller cam, C-6 wide ratio and then I decided to go with a 2.75 rear gear for milage. A clear case of brain cramp from the start. FE's with good milage in the same sentence. I have most likely opened myself up for some well deserved comments. As I said Kevin one heck of a job and a good choice of engines.
Don
deadheadno1
Post by deadheadno1 »
That is a very beautiful power plant, cold ones all around on a job well done.
Now, I don't want to stick my nose in where it's not wanted and I'm not trying to be politicly correct but,
those are not DOHC heads, they are SOCH design. Unless my eyes decieve me there is only one cam under each of those valve covers.
To my knowlege Ardun never produced any overhead cam heads, at least for sale to the public. They made "overhead valve" himi-head designs for Ford flathead engines.
Tom :2cents:
Tom: You are correct, they didn't make OHC heads, but were (and still are) overhead valve OHV heads. I corrected my post. I just thought the covers looked so very similar to the modular covers.
DM66FE482
Post by DM66FE482 »
I do remember that now. :oops: Needless to say I don't know much about these family of engines.
Don
Don, I would be more than happy to trade with you if you are unhappy with that BAAAD FE :lol:
I'm in the same situation; I would like to DRIVE to Slickstock, rather than tow with my 12 mpg tow vehicle. Ignoring aerodynamics, the truck should be several hundred pounds lighter than the Mark VIII's , and the multiple Lincolns I have had would easily exceed 20 mpg with the a/c blowing and my heavy foot!
Deadhead,
If you are referring to Kevin's engine, it IS a DOHC, two cams per head, one cam driven off the other via chain. I get a lot of comments; "Hey, you've got a Cobra engine in there".
My typical reply is ; " No, Lincoln had it first, so it would be more correct to say you have a Lincoln motor in your Cobra :twisted:
kstones63
Post by kstones63 »
Don, That would have been a good deal on the Mark VIII for $500. I paid $500 for my car, parted it out and sold about $650 worth of parts real quick so I had the engine and trans for free plus made some money to put towards the rebuild.
Paul, Do you have a Lincoln DOHC in your truck?
I might start using your comment that " No, Lincoln had it first, so it would be more correct to say you have a Lincoln motor in your Cobra"
I like that much better.
Kevin
kstones63
63 F100
kstones63 wrote:Don, That would have been a good deal on the Mark VIII for $500. I paid $500 for my car, parted it out and sold about $650 worth of parts real quick so I had the engine and trans for free plus made some money to put towards the rebuild.
Kevin
Haven't QUITE made it in yet :( . My Sigh!clone project is eating up all my resources. I've been playing with the VII's and VIII's for quite some time now.I currently have another 96 LSC, as well as my old (occasional) bracket-racing 98 LSC. Same story; bought a rough 96 because I needed a (one year only) secondary throttle controller for my 96 LSC Diamond. Engine turned out to be in good shape so it's going in my 65 SB with a Fatman front. It'll also get the MK VIII IRS with bags and Shockwaves on the front. It'll never be near the quality of yours, but should be an economical driver. Unfortunately, in addition to the Cyclone, I have several other on-going projects, including eventually stuffing a Continental 4.6 in the middle of a uni. :twisted:
In the far future,IE, when I run across a donor, I will put together a Coyote-powered, Panther-footed Uni Slick, assuming I can still turn a wrench in a few years :D
The local members will tell you I'll be lucky to have my already-running stock Uni completed in time for SS 10! Luckily, I think I still may have an as-yet unseen slick already stationed in the Midwest :lol:
kstones63 wrote: " No, Lincoln had it first, so it would be more correct to say you have a Lincoln motor in your Cobra"
Kevin
http://www.youtube.com/watch?v=QDbON8udTPo
Couldn't help myself........... :mrgreen:
Stunning Kevin - just stunning!
Do I get a ride at SS?
:mrgreen:
FORDMANLCRACKEL
Post by FORDMANLCRACKEL »
You've done a great job Kevin.
What year was the Mark VIII ?
ezernut9mm
Sweden
Post by ezernut9mm »
looks cool kev. love the color.
fire truck
Post by fire truck »
deadheadno1 wrote:That is a very beautiful power plant, cold ones all around on a job well done.
Tom :2cents:
Kevin's Engine is a DONC 4.6 from a MK VIII....
fire truck
Kevin, that is clean!
When are you sending me the old yblock?
