1st Post-66 F-100
Posted: June 18, 2007, 10:43 am
Last Winter I bought a 66 f-100 long box. (right out of field- a section of tree is still stuck in the grill and grew to be very thick on both sides). I have a knack or curse for pulling stuff out of fields and letting the frame off begin. My cars may be environmentally unfriendly, but if I did that restore them, they would be in landfills.
I have removed the front clip and engine. The only thing still attached is the steering box.
I stripped the inside of the cab BARE. I still have to pull front and back glass.
I got out the aircraft stripper and have the factory base coat on the tailgate and left side.
Here is what I know:
66 F-100 long box (I know the cool guys like the short box, but I REALLY like the elongated look you get with the bigger box.)
352
3 on column
3:25 rear (that was the standard ratio correct)
custom cab (long speedo)
2 tone white/medium blue
I resisted joining this forum earlier so I would be forced to do my teardown without a "support group." On my own I found the cover that hides the secret bolt to pull the fenders off. I found the secret button to get the light switch out (this was sort of like my first date with the truck). I got all bezels off the dash. I pulled the ignition switch without having a key. I got the trim off the dash (2-3 clips were the casualty). Just about everything else was simple disassembly.
Status Quo: I am stripping the box while it is still on the truck. I will pull the box to get the cab side. Will por 15 the underside, do brush on liner for the inside, and (tenatively) re-shoot factory colors on the outside. While the box is off I will restore the bumper (white-no frills on this truck) and por 15 the frame and rebuild the rearend. I did not know until I had the truck home for about a month that although the axles are there, the center section is emptied. Fortunately the guy who scavenged from the truck did a great job in showing respect for the job and not causing any collateral damage. He gives me the perfect excuse to get a power trax unit and go to a 3:50 rear end.
Over time I look forward to raiding your minds for the hardstuff and your parts bin to turn talk into action.
I recognize two names on this site already. Phil is the Hardtopkiller from the Torino site and Hawkrod is also a Blue Oval "go to" guy.
The redeeming quality of pulling junk from fields is that is neutralizes my piss poor skills as I cannot possibly hurt anything and anything done even marginally right is considered restoration.
My junkyard jewels are:
a) 70 Torino GT-4 speed-351 4V, 4:33 with gearvendor unit.
b) 69 Mercury Marauder -390-gold/black vinyl top- base model
c) 77 Mark V-460 and just cool
I have about another year before re-assembly even becomes a thought, but I figured I would check in now.
352
3 on column
