Installing side chrome on 66 longbed
Posted: June 11, 2012, 11:40 am
by NorthsideSlick
I have a chance to buy the side chrome molding for my 66 long bed.
I know you can buy the clip sets
But before I do...
1. is it a pain to do if it did not have it before?
2. if you have done this do you have any tips?
Thanks, B.
Re: Installing side chrome on 66 longbed
Posted: June 11, 2012, 12:43 pm
by banjopicker66
I just primered my '66 longbed, and reinstalled the original aluminum or "chrome" with new clips.
If you get the set from Rick at Carolina Classics, you will need to insert the clip into the trim, line the clips' studs up with the holes to insert them, then screw it down from the backside.
The original clips were plastic (nylon?), and the new ones are all steel. The originals on my truck came with a putty-ish like material at the top of the stud to seal the hole. The new replacement clips did not have anything to seal the holes, so I bought a package of 5/16ths O-rings to slip over the studs, and they seem to have worked.
The bed was easy to do, but all the points are accessible from the backside.
I haven't done the cab, hood or doors yet.
However, based on the work I had to do to remove the original ones, there are some spots on the cab you will need to pay attention to.
To remove the cowl ones, you will need to remove the floor vent, and possibly the heater on the passenger side. They are hard to reach.
The front-most original cowl clips are different than the other originals, but the replacements work fine even though they aren't identical to the originals. These are the hardest to reach.
The rear curve on on the cab may require removing the fuel tank, at least on the driver's side.
Door clips may not be easy to reach with the window glass installed; I will install mine before I reinstall the glass and install the new rubber components.
Hope this helps.
Posted: June 11, 2012, 12:47 pm
by NorthsideSlick
My 66 did not come with the trim, after reading what you wrote it sounds like something I might want to pass on.
Thx, B.
Posted: June 11, 2012, 1:50 pm
by bmcgc
i wouldnt drill holes if there are none. Double sided tape is a wonderful thing.
