Bed floor repair.... HELP!
TroyPilcher
Post by TroyPilcher »
Ok... Be gentle I'm very green to this truck stuff. I am in the process of buying a 1965 ford f100. It's in pretty good shape but the bed floor is really ruff. I don't see a fix using wood available unless it's a step. So how can one replace the metal bed using the same type of original material? Help!!!!
sully5
Re: Bed floor repair.... HELP!
Post by sully5 »
I have only found patch panels for the floors of these trucks and lining up and welding a bunch of patch panels would be a nightmare. Someone on here installed an entire floor cut out of a later model. A couple of us, went down to the local steel supplier and bought a sheet of tread plate.
FYI, a steel company can order tread plate in sizes bigger than 4x8. Mine was ordered big enough (6'x10' IIRC) to cut the wheel wells out and install it in one piece. I also had a 90* bend at the front with a 3" vertical because my bed front panel had some rust too.
Rusty 63
Post by Rusty 63 »
another build used a new late model ford floor right from the dealer parts dept
64 f100
Post by 64 f100 »
Long bed short bed, what have you got? Might be easier to try and get a better bed later and just cover up the floor for now.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
TroyPilcher
Sorry it's a short bed 1965 f100. Early model.
Anthony
Post by Anthony »
pics would help a lot on how to tackle this project.. I am replacing mine as we speak.. I cut mine all the way out and am installing a $10 bed floor from a late 80's truck... I am using a grinder with wire brush and cut off wheels, and a saw saw. I will use a 110 mig to get it welded back in. Anything is possible if you put your mind to it and take your time and plan it out...
viewtopic.php?f=1&t=26816
by the way Troy, Welcome to the Slickest place on the web.. :hello: .. from West Virginia
Rusted64
Post by Rusted64 »
Seen a few use diamond plate.
Probably pretty expensive, but it does look good.
Also, there is another thread in Truck Talk that did the late 80's swap.
J
1964 F100, 292ci
1963 Buick Wildcat, 401ci
They just don't make them like they used to.
62bigwindow
Post by 62bigwindow »
I am using 14 gauge sheet metal.May not be for everyone but with a flipped axle I can have one piece braked at a local shop to clear step notch and axle.If done right I like the look of a smooth bed floor, but I have been accused of not being right in the head also. :)
DukeRoche
Post by DukeRoche »
I would say your better off looking for another bed but thats due to my lack of autobody skills.
The Green Machine
GO ARMY, BEAT NAVY!
rwhistles
Post by rwhistles »
RPD sells an 8 foot 70s model floor for about 389 dollars.that the way I'm gonna go when I get around to it.
but I live pretty close to the RPD warehouse in ocala fl. so shipping wont be a problem.
1961 F350 pick up
1962
1963
1964
1965
1966 F350 camper
jwh f-100
Post by jwh f-100 »
check out my build thread.. i used a floor from a '86.. Free!!!
viewtopic.php?f=32&t=8950
Jason
Beer will change the world.
I don't know how but it will.
Post by Gritsngumbo »
rwhistles wrote:RPD sells an 8 foot 70s model floor for about 389 dollars.
RPD? Do you mean NPD or do you have a link?
65MercTruck
Post by 65MercTruck »
Hey all. I know this thread is old, but I JUST happened upon it. I'm currently repairing the bed floor and bed head in my 65 short style-side. Here's some photos I took over the weekend. I'm only just beginning this project.
I recently located a bed section cut from a 65 long bed. Took me a year of looking through swaps, junkyards, online, etc. These beds are tough to find! So, here starts the project! I'll post my progress in the coming weeks / months. Wish me luck!
Here's what my bed looks like now.
This is the bed section (half of a long-bed I recently purchased) that I'm taking apart. Drilling out the spot welds.
More drilling and popping the spots.
One side removed. Same process for the other side will follow.
1965 Mercury M100
shorty style-side
351W 4spd w/ frnt disc
Dana 44 rear w/ trac-loc
Built in Oakville, Ontario
rderr
Post by rderr »
viewtopic.php?f=32&t=31235
In the build thread you can see a few pics of the bed floor replacement I did. It was a center section from an 86 F150 and fabricated pieces in each corner. If you want to see more PM me and I will get your email add and then send you a powerpoint file I put together that documents it.
I do not have any pics. My 65 short bed needed the front 6"s and the front crossbrace. I found that the second cross brace on a long bed was the same as the front one on the short bed. I had a bed that was otherwise junk and cut this brace out with the 6" of floor and needed and welded them together. Its a lot of welding and grinding, but it looked good when done. I also have a 'spare' short bed that has a rust-free floor, but the sides could be better. PM if interested, I'd let go for less than the RPD/NPD floor.
64 f100
Post by 64 f100 »
Bed floor is available from NPD but cost with shipping is about 670$ for me. Floor is 500$ . These ship out of Michigan if I remember what I was told.
1961 F350
1991 Capri
2011 F250
2004 Lexus
