Source for hood hinges that last?
dsrtjeeper
Mine are shot and I'd like to replace them. My hood sticks up in the rear. I've heard that new ones aren't good quality.
1966 F100 LWB
Balanced 390 .060 over, Comp 270s, Performer RPM intake, Quick Fuel 680VS carb, full length headers, gasket matched/fully ported C6AE-R heads, 2-1/2" duals, C6 and 3:54 gears with Tracloc.
Re: Source for hood hinges that last?
Kevindsrtjeeper wrote:Mine are shot and I'd like to replace them. My hood sticks up in the rear. I've heard that new ones aren't good quality.
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
dsrtjeeper
Kevin; Quit lookin at my hood you perv! Xmas is coming and I know what I want....ahem.
1966 F100 LWB
William-in-St George
Mine were shot so I bought a set of replacements from a well known supplier of aftermarket parts. I wound up using my old ones after trying and failing to adjust the hood using the replacements. If you want the replacement hinges I have, (I wont use them) send me a PM and we can discuss.
William-in-St. George
before i changed my hood it was sticking up in the back, i put a couple flat washers between the hood and the hinge on the front bolt and it took care of that. i did not need them with the new hood.
dsrtjeeper
What are guys using that build show trucks or restore theirs?
1966 F100 LWB
Hood up in the back is usually not bad hinges, it is usually bad adjustment. Although it is counter-intuitive, loosen the hinges and lift the hood as far up and back as you can and then tighten the hinges. I think you will see the back sink down. Watch carefully to make sur you don't hit the cowl but otherwise this is usually the problem. The hinges actually over center and pull the back of the hood down and if the hinges are rotated forward this does not happen and the back stays up. Hawkrod
dsrtjeeper
Thanks Hawkrod! Will try.
1966 F100 LWB
Dave Rogers
Mine are shot when the hood blew up on the hiway, a friend was borrowing it... I've heard you can heat the pins and pound on them to tighten them up. I have a couple of sets that I'm going to decide which is best.
DAVE
dsrtjeeper
Hawkrod....have a question
Loosen all the hinge bolts on hood and cowl? Then force hood wide open and back toward windshield. Tighten.
1966 F100 LWB
