Ground wire
Posted: November 2, 2012, 1:10 pm
by bmcgc
My battery ground wire attaches to a GIANT bolt on the block just under the exhaust manfold.
Is that correct?
I cant find a ground wire with a terminal large enough to fit the bolt and I dont want to drill any extra holes.
I was planning on grounding the alt there as well.
Re: Ground wire
Posted: November 2, 2012, 1:36 pm
by HiBoy63
If an FE yes. You can see the bolt in this pic.
right side of the block as your looking at the pic about half way down the block.
Re: Ground wire
Posted: November 2, 2012, 3:03 pm
by bmcgc
So where do you find ground wires with giant terminal ends?
Re: Ground wire
Posted: November 2, 2012, 5:43 pm
by bmcgc
Well I put the terminal on the anvil and beat it like Ike beat Tina.
It flattened out enough to drill a hole big enough for the bolt.
It seems to me that the engine should be grounded to the frame if the battery and alt ground to the engine.
Re: Ground wire
Posted: November 2, 2012, 10:05 pm
by William-in-St George
True! I always add a ground 2ga from that big bolt over to the vehicle frame. I buy cable and ends that fit the bolt and soldier them onto the cable. Stick the cable end in a vice heat some soldier with a little butane torch and stick the cable end in there. When it cools you will have a solid long lasting connection. Add some heat shrink and the cable you just made will look factory.
Re: Ground wire
Posted: November 3, 2012, 12:57 am
by HotRod66
I Make my OWN terminals!!!! I have a load of Diff size Copper pipe! Just cut how long ya want the terminal put the Cable in one end of it and take a chisle and hammer to crimp it! Heat shrink! Then flaten out the other end drill a hole and round off the end.
Re: Ground wire
Posted: November 3, 2012, 2:32 pm
by Hunter's 64
bmcgc wrote:So where do you find ground wires with giant terminal ends?
Try Tractor supply , or a heavy equipment (cat/ringpower) for heavy duty or larger ga. cable and conn. :2cents:
Or if you wish to make your our these guys have every thing you need.
http://www.delcity.net/navi?action=home ... nAodskkAuA
Danny
Re: Ground wire
Posted: November 4, 2012, 9:03 am
by BarnieTrk
You can also find lots of large cable teminal ends from your neighborhood welding supply store.
BarnieTrk :2cents:
