Oily's 1966 F-350 aka "Puller"
Posted: December 17, 2012, 9:37 pm
Hi again! Starting a thread to share work on my '65 F-350. It will be a rather slow project for me as time/money is available. This is not my only project.
This is him as found. It was on the property of my late grandfather. It served in his oil well service business as a "pulling machine". A few pictures of it "as found".
It appears to be mostly original with the exception of the 2-ton, vacuum assist, 2 speed rear. I would like to get it back to the original 1-ton dana rear at some point. It has a 352 engine and New Process 435 4 speed tranny.
I power-washed the truck and pulled it into the shop. Block sat with diesel in it for weeks, flushed several times before I attempted startup. Had some issues with the ignition (I thought) and fought that for a while. After replacing soloniod, starter, and battery/cables finally figured out bad ground. New plugs, condensor, coil, wires, blah blah blah and the engine is now running well....has good compression, no smoke, keeping temp and oil pressure, holding fluids and in the right places.
Here is a couple shots of it in the shop after cleaning.
I will begin to disassemble the truck next. I just need a little more time to finish my '65 before I start that process here. I do "piddle" with it as I have time. Hood/doors off, seats out, dash out, inner fenders/wheel well out. It is consuming about a 1/4 of the shop.....so I have to justify it being there somehow. I look forward to sharing the project as it moves along.
