Heater hoses
Limestone66
Heater hoses
Post by Limestone66 »
Been a long time since i've even messed around with this. Limestone's heater hoses had been cut when i bought it last March, and both of the pipe connectors were plugged. Gettin rather chilly down here in Florida so i began troubleshooting all this. Blown fuse to heater switch fixed, now have a 2-spd heater that works fine. Defroster knob also pulls out fine and blows strong through the vents on the dashboard. Where exactly does the heater hoses connect to from the heater core. She be a 352. And is there a connector i can use for one of the inlets or outlets to hook my stock sending unit to it. Scratchin my head on this.
Long live the 352
........Ron..........
1966 Ford F250 Custom Cab {Longbox}
1996 Toyota Camry {Wifes ride}
1940 Harley Davidson knucklehead {Retired in 2006, gave to one of my sons in 2010}
1975 Harley Davidson XLH {Groundpounder}
2005 Harley Davidson Deluxe {Nostalgia} Almost home 'girl'
In memory of Donald G. Roswell- My freind and 'brother'.
f100jim
Re: Heater hoses
Post by f100jim »
From your description,(Defroster knob also pulls out fine and blows strong through the vents on the dashboard). is your heater a deluxe unit with separate temp and heat controls under dash? And are you talking about the water cut off valve on the end of one of the cables under the hood as as a sending unit?? I can get a pic of my set up if you need it.jim
f100jim
Re: Heater hoses
Post by f100jim »
If limestone or anyone else needs this, here it is.The hose end(return line) you don't see that good, connects to the top of waterpump.Image
Limestone66
Re: Heater hoses
Thanks jim, you have it right there on the pic. Cleared everything up. I'll tap into a plug near my factory sending unit and use that. Not a deluxe unit with seperate controls, just trying to decipher which hose goes where without sacrificing one of my sending units. Return goes to water pump, inlet hose to a plug near the distributor on the intake manifold. Now the big question is whether the heater core is any good.
Long live the 352
66CC
Re: Heater hoses
Post by 66CC »
You'll find out fairly quickly. :shock:
Re: Heater hoses
Post by rickairmedic »
What in the world do ya need heat for heck it was 75 in Tampa today around the corner from you :D . We had a Balmy high of 44 today and I was running around in the service truck with the drivers window open as the sun was cooking me :D.
Limestone66
Re: Heater hoses
Thin blooded and awful chilly up here 400ft. above sea level. coldwithsnow.gif
Long live the 352
Re: Heater hoses
LOL I grew up in Tampa just up the road from you . I was just busting your chops :D I remember 50 there its worse than 30 here the humidity down there makes the cold go straight through you .
Limestone66
Re: Heater hoses
Then you know what ima talkin about. It rainin makes it even worse.
Long live the 352
