Mustang gas tank venting
- 1965fordf100
Question for those of you that have done the mustang under the bed tank install....i just bought a 22 gallon tank for a 70 mustang...what did you all do for tank venting? I have seen some marine fuel fill necks that have a vent built in, but not sure if that is what I need...and/or I have seen some guys weld in a 1/4" npt fitting and put in a rollover valve...what are the general thoughts on this? I would prefer to not weld on the tank but will if I have to...
Phil
Re: Mustang gas tank venting
I used a piece of steel 1/4" tubing installed into the filler neck, before I put fuel anywhere near it.
I then put on a piece of rubber hose and used another piece of steel line with a filter outside the frame rail on the passenger's side.
You can see what it looks like in the picture.
American born, German blood, Texan attitude..... And people wonder why they call me "Moose."
66 F-100 Too much to list
05 F250 The Tank
05 F250 The Tank
- 1965fordf100
This might be a dumb question...what kind of filter and what's the purpose of the filter? Keep dirt and debris from getting into the tank?
Phil
- charliemccraney
Can you get a vented gas cap?
- 1965fordf100
I'm gonna be running a fill cap in the bed floor...plan was to use a marine style fill...I have seen one that may be vented but not sure if its proper to prevent vapor lock
http://www.westmarine.com/webapp/wcs/st ... PHq0ny9KSM
Phil
I am running a marine filler through the floor. And the filter is most definitely to keep anything from going up the line and blocking it (mud daubers.)
05 F250 The Tank
05 F250 The Tank
Before I filled it with gas for the first time, I threaded a 3/8 hose barb just above the fuel filler so I could hook up a hose to coil up.
Seems to work well.
J
Seems to work well.
J
1964 F100, 292ci
1963 Buick Wildcat, 401ci
They just don't make them like they used to.
- charliemccraney
I don't have a mustang tank but the only vent I have is in the gas cap and it has worked great.
- jkimbrel65
I have the mustang tank with vented cap.Works great.
Mike
Mike
I tried being normal once...
- 1965fordf100
So you have a door in the bed floor that opens to access the filler tube that has a vented cap? Do you have pics of your setup?jkimbrel65 wrote:I have the mustang tank with vented cap.Works great.
Mike
Phil
