vent door
Posted: March 20, 2013, 10:49 pm
by bmcgc
My 66 vent door is triangular.
The vent door on a jy 66 with the cable control is oval.
Do they interchange?
Re: vent door
Posted: March 20, 2013, 11:05 pm
by ken462
Yes,
Simply take a 4in grinder w/cutting wheel and make the oval a triangle
Re: vent door
Posted: March 21, 2013, 6:49 am
by bmcgc
Are you being serious?
Re: vent door
Posted: March 21, 2013, 6:55 am
by F7BIGJOB
They won't interchange.
Re: vent door
Posted: March 21, 2013, 7:54 am
by bmcgc
Re: vent door
Posted: March 21, 2013, 3:09 pm
by qwertyd10n
Does anyone know if the triangular vent doors are being re-manufactured anywhere?
Cheers,
Dion
Re: vent door
Posted: March 21, 2013, 5:21 pm
by F7BIGJOB
qwertyd10n wrote:Does anyone know if the triangular vent doors are being re-manufactured anywhere?
Cheers,
Dion
There was a post about the differences on here last year or so on model year differences, my 65 has a cable op on the drivers side, triangular on the ps, is there a market for these? I can try to look next time I'm at the junkyard, but the trucks Samdog66 and I looked at [for other things ] the cowling and lower cab was rotted to death.
Re: vent door
Posted: March 21, 2013, 6:07 pm
F7BIGJOB wrote:qwertyd10n wrote:Does anyone know if the triangular vent doors are being re-manufactured anywhere?
Cheers,
Dion
65-66 4x4s and big trucks had one of each, except the 66 f100 4x4 which had 2 triangle vents like the 2wd trucks
Re: vent door
Posted: March 21, 2013, 6:45 pm
by F7BIGJOB
Thanks Brian
Re: vent door
Posted: March 21, 2013, 8:17 pm
by bmcgc
hmmmn.
The 66 2wd in the salvage yard has oval vent doors with cable pulls.
The passenger side is eat up but the driver side works perfectly.
There is a 63 sitting next to it that has a vgc header panel I tried to pull off today but one of those nut clips inside the fender is broke and the bolt spins, I couldnt hold a wrench on it and turn the bolt both so I had to leave it.
2.5 hours in the yard and I left with nothing.
Re: vent door
Posted: March 21, 2013, 10:20 pm
i have never seen a 65-66 2wd with oval vents and i have parted out many trucks although none have come from the east so i wonder if its a plant thing
also i always take battery sawsall to salvage yard for bolt issues like that.
Re: vent door
Posted: March 21, 2013, 10:56 pm
by HiBoy63
Wondering did that 66 with oval vents have inside step cab. If it did probably and early model with 66 grille.
Re: vent door
Posted: March 22, 2013, 12:00 am
by bmcgc
No cab step, no door tag.
Im 100% sure it has a 66 grill and core support, beyond that who knows.
Re: vent door
Posted: March 24, 2013, 8:01 pm
by bmcgc
Went back today with the proper tools, someone beat me to teh header panel, it was gone.
Re: vent door
Posted: March 31, 2013, 1:50 am
by f25065
I did the triangle-to-oval "conversion" on my '65 2wd; will be doing the same on my '66 4x4. Far more convenient. Best to remove the inner flange on the oval vent. Trivia: (that I don't know the answer to; maybe someone does)... Anyone know why they switched from the cable-operated oval vents to the reach-down-to-your-foot-while-driving triangle vents?
Norm
Re: vent door
Posted: March 31, 2013, 9:35 am
f25065 wrote:I did the triangle-to-oval "conversion" on my '65 2wd; will be doing the same on my '66 4x4. Far more convenient. Best to remove the inner flange on the oval vent. Trivia: (that I don't know the answer to; maybe someone does)... Anyone know why they switched from the cable-operated oval vents to the reach-down-to-your-foot-while-driving triangle vents?
Norm
i say its because plastic vents are cheaper to manufacture.
may have had something to do with the new heater design in 65 too.
the earlier deluxe heater had the vent door in the heater.
