a/c queston
Posted: July 29, 2007, 6:37 am
by Rustbucket
I have a 90 tempo ( collector car someday ) lol. When you run the a/c, the engine runs hot, not overheat ,but close.Then the a/c blows warm. a/c works good untill it gets hot. It has been converted to r-134 a couple years ago. I dont know much about a/c . Appreciate any help. Dale
Posted: July 29, 2007, 9:50 am
by dotcentral
One place to look is the cooling system on the tempo. It might have something near the end of it's life span, and the extra load of the a/c is just a little more than it can take. I'd check it out, hoses, thermostat, coolant. hopefully it's something cheap and easy, and not your radiator or heater core.
Posted: July 29, 2007, 10:18 am
by shawns fords
check to make sure your fan is running when the a/c is on, its been a long time, but if im correct, there was a low speed and high speed relay, I might be thinking about the taurus, and Tempos might not have that, as well.
Posted: July 29, 2007, 10:33 am
by ELpolacko
Electric fan is worn out. Solved the same exact problem a few years back on my landlords Chrysler convertable. Everything seemed to work fine but overheated and the AC performed poorly.
The fan worked but didn't pull enough air through the heat exchangers (rad and condenser) to drop out enough heat. New motor and everything was tip-top.
Posted: July 29, 2007, 5:03 pm
by Rustbucket
I replaced the rad. , theromstat ... I picked up a new fan motor today . I`ll give that a try. Thanks again for your advice. Dale
