'74 brake hoses too short for '66 f100
Posted: April 16, 2013, 1:56 pm
by SAD66
I just installed a 74 disc brake front end on my 66 f100. I purchased new brake hoses for a 74 from Pep Boys but they are too short to clip into the stock 66 brackets by about 2". Do I need to buy a different year hose, build a new mounting bracket, or have custom hoses made? The ones I bought are 18 1/2", in the Dennis Carpenter catalog they say they're 19 1/2", but they could stand to be 20 1/2". Any ideas? Thank you in advance.
Re: '74 brake hoses too short for '66 f100
Posted: April 16, 2013, 4:35 pm
by DV65CustomCab
When I did my conversion I had to move the mount bracket out from the frame at least an inch. It's pretty simple to do: I cut a spacer from a piece of square tubing the distance I needed to move the bracket, put it between the frame and bracket and just used a longer bolt to hold it to the frame. Works like a charm. Your metal lines will, of course, have to be moved to match the new location.
Posted: April 16, 2013, 11:20 pm
by jamesdfo
Lower the truck, then the hoses will reach
....only half kidding:)
Posted: April 17, 2013, 4:21 pm
by BlueGhost
When I did my swap I took the hoses down to NAPA and we matched them to a longer set that had the same fittings on each end. I think the ones I found that worked ended up being from a Dodge van from the 70's or 80's.
I've sense swapped them for stainless lines that I ordered from Summit.
Posted: April 24, 2013, 9:54 pm
by SAD66
Thanks for your replies. I think I'm going to try and find some longer ones first.
