Power steering needed.....Bad!
Posted: April 18, 2013, 8:46 am
by shaff64
Okay, anyone know what I can do now to add power steering to my 63? I seen there was a link on this site that took me to a aftermarket add on power steering unit however, it won't work with a three speed on the column truck. I worked to hard to return it the tree so that's out.... What can I do to add power steering? Change out everything and remove the motor and trans and cut out the crossmember and add rack and pinion? I know a guy that has a power steering unit that came with his 63 uni, Did the original ones work okay?
Or should I just start lifting weights now, and get ready for the real work out to drive it. LOl
Any help would be appreciated!
Re: Power steering needed.....Bad!
Posted: April 18, 2013, 8:56 am
by bird55
FYI, I don't have PS on my 64 either. But I do have newish front end components and good tires with proper inflation. It takes getting used too to learn how to drive it as most of us get pretty spoiled and lazy driving anything new.
It's part of the "driving experiance"
I like it just fine.
Posted: April 18, 2013, 9:10 am
by Hunter's 64
http://www.classicperform.com/tech_arti ... eering.htm
I beleive this will work with stock column. you can use your stock steering column with the no-limits R & P if you cut the steering shaft at the botton next to the steering box inner and outer and reweld a D.D. universal joint on the end, has been done by people on this site.
Danny
Posted: April 18, 2013, 10:28 am
i dont know what you have been told but ps is not a necessity, its a luxury item allowing the driver to turn with a finger instead of 2 hands.
bird55 wrote:FYI, I don't have PS on my 64 either. But I do have newish front end components and good tires with proper inflation. It takes getting used too to learn how to drive it as most of us get pretty spoiled and
lazy is the operative word in the quote above.
Posted: April 18, 2013, 10:34 am
by Gritsngumbo
No Limit Engineering makes and sells a Power Rack and Pinion setup that bolts onto a straight axle vehicle.
You will need to change the steering column so you have an end to tie the column to the rack. Runs about $700 the last I looked.
Posted: April 18, 2013, 11:54 am
by bmcgc
What size tires are you running?
Im putting ps on my 66 because I will one of the few who have ps on a Slick with a 3 speed column shift and I want to be special.
Im running 225-70-15s on stock rims. Its not effortless, but its not hard either.
My next set will be 235-75-15s.
Posted: April 18, 2013, 2:28 pm
by shaff64
Ya, My sons talked me in to putting on 16" M/Ts with 265 /75R Good year tires all the way around on my truck. I have not drove it yet, I was just thinking that it is going to be a bear to steer. Maybe I'm just getting nervous or nothing. I don't mind the hard steering of a non power unit. I just didn't know if I could even turn the wheels at a stop. I sure like the input above here. This site is something else..... Thanks you very much! I guess I will need to wait and see in two weeks if I can drive it with these wheels and tires on it.
Posted: April 18, 2013, 2:43 pm
by Gritsngumbo
Once rolling you're probably going to be OK, but at a stop or slow speeds it's probably going to be bear. Top notch front end components, well lubed will help. I have 195's on the front of Little Red (64 short) and it's tough to steer while stopped or at slow speeds (driveway, parking lot, etc.) but probably could use new kingpins, etc.
Posted: April 18, 2013, 4:58 pm
by 64 f100
You can still get the original style power steering for the truck, and it will work with 3 speed, no porblem. As to the bigger wheels and tires, I advise you to go with a narrower tire, but the 16's are a good idea. I have a 64 3/4 ton that doesn't have power steering and it drives well. I would see how it turns out first, before doing anything.
Posted: April 18, 2013, 6:54 pm
by Toyz
OK, I guess I'm turning into a wuss! While I readily agree lots of the tough steering problems are the result of poor maintenance and worn parts, my towtruck is almost intolerable at driveway speeds. I have re-arranged the pecking order of my shop to avoid the sharp 180 degree turn into the taller stalls. It still takes several forward and back manuevers to make the turn, and it's no fun! I am 6' 1" and 220 lb. , so with the later model seat, the big wheel also is almost binding against certain parts of my anatomy!
The Classic Performance kit may be the answer of choice, although I don't like the linkage-mounted cylinder type assist. I need to contact No Limit to determine if their conversion can be used on an F350 Slick, which was not originally offered with power steering. My '61 uni 6 cylinder drives just fine with no assist, but the '65 with a 385 is a pleasure with the later factory setup. The big advantage to the '65 is that I can literally utilize four wheel steering under many conditions
Posted: April 21, 2013, 9:40 am
by douglloyd
Sure I swear and grunt when parking a longbed slick in today's parking lots. I even have the complete setup from a '76 F-100 for three on the tree with power steering. But I can't bring myself to put it in my '66 project.
Later steering wheel and column look silly in a stock slick cab.
Something else to fail and fix.
One less thing to load on an old engine.
Everybody who sees these trucks usually likes the "huge" stock steering wheel.
Cranking the wheel while stopped is just as hard on the tire treads as it is on your shoulders.
As far as the wheel making contact with certain parts of the driver - run the seat back?
Maybe we all just ate less or healthier back in the 60's?
Doug in east TN
Posted: April 21, 2013, 9:59 am
Gritsngumbo wrote:Once rolling you're probably going to be OK, but at a stop or slow speeds it's probably going to be bear. Top notch front end components, well lubed will help. I have 195's on the front of Little Red (64 short) and it's tough to steer while stopped or at slow speeds (driveway, parking lot, etc.) but probably could use new kingpins, etc.
This is one of the problems with manual steering vehicles vs modern cars that are ALL PS. We have forgotten as a society how to drive them.
I have 225 x 60s on the front of my truck with a 14 3/4" steering wheel. Your arms best not be sore if you want to turn the wheel sitting still and especially if you have pressure on the brakes (both wheels will fight you in opposite directions then). Plan your turns and have it moving to steer it, if you're doing it right you can drive the thing with one hand.
I may still add PS to my 64 someday (I have bad shoulders) - I will likely go with the Toyota 4x4 conversion though. You can also add on the Ford slave cylinder PS setup - it was still in use up into the late 70s on Granadas etc. so they are still out there. It's a pretty simple system and will fit about anything. The biggest issue with it is worn seals on the slave cylinder - these can be bought rebuilt and really aren't that hard to put new seals in yourself.
Posted: April 21, 2013, 10:57 am
by bmcgc
douglloyd wrote:Later steering wheel and column look silly in a stock slick cab.
Something else to fail and fix.Doug in east TN
You can make a later column look exactly like your 66 column. Its a little more work, but what isnt a little more work on a 47 year old truck?
Posted: April 21, 2013, 11:18 am
douglloyd wrote:Maybe we all just ate less or healthier back in the 60's?
not really
its all in your head
if you dont have it and never did its not likely to be thought or worried about.
its just like any of the convenience items
once you get used to them its hard to cut them out
it can be done just takes some getting used to
i lived without electricity and running water for a long time, its not the end of the world and after a short while you dont think much about it. nice to have but not a requirement to live happily.
tv and cellphones are the same way, internet too.
the more conveniences the lazier one gets and the more complicated things become when one or more of them break down.
Posted: April 21, 2013, 6:39 pm
by bobenhotep
I run 215/75 r 15 tires with 44 psi, and also grease the heck out of everything. It does not steer too badly, I spent enough time driving a deuce and a half with no power steering to get a pretty good no power steering technique down. In parking lots you have to roll just a little, and steer with the wheel close to your chest for leverage and get most of your power from pulling down on the wheel, kinda like pulling down on a sleeve to break balance in judo, if anyone knows what I am talking about.
Posted: April 21, 2013, 8:23 pm
by samdog1966
What you never had, you'll never miss.
Posted: April 21, 2013, 9:29 pm
by Toyz
douglloyd wrote:Sure I swear and grunt when parking a longbed slick in today's parking lots. I even have the complete setup from a '76 F-100 for three on the tree with power steering. But I can't bring myself to put it in my '66 project.
I don't mind replacing tire treads; I kinda want to hold on to my shoulders!
Never thought of that! Now if I can just find the power seat button!
Kinda like my trucks; my body was somewhat newer back then!
Doug in east TN
Posted: April 21, 2013, 11:00 pm
by ezernut9mm
i have had manual steering trucks that steered just as good as ps trucks. yes, it's true that at a complete stop they are a bugger to steer, but once you get used to steering as you move (even at half a mph) they work just fine. i had a 67 f250 that i could literally one finger as long as there was some movement forward or backward. the 66 i have now is almost as easy.
Posted: April 24, 2013, 1:58 pm
by Hunter's 64
shaff64 wrote:Okay, anyone know what I can do now to add power steering to my 63? I seen there was a link on this site that took me to a aftermarket add on power steering unit however, it won't work with a three speed on the column truck. I worked to hard to return it the tree so that's out.... What can I do to add power steering? Change out everything and remove the motor and trans and cut out the crossmember and add rack and pinion? I know a guy that has a power steering unit that came with his 63 uni, Did the original ones work okay?
viewtopic.php?f=6&t=30050
Danny
Posted: April 24, 2013, 7:59 pm
bobenhotep wrote: steer with the wheel close to your chest for leverage and get most of your power from pulling down on the wheel, kinda like pulling down on a sleeve to break balance in judo, if anyone knows what I am talking about.
Good point;
Take a look at a NASCAR racer in his car on the race this weekend - notice how they sit in relation to the steering wheel.
