Carb Swap and Engine Paint
chris401
Post by chris401 »
Swapped out the 750 for a 600. A lot more driver friendly for the heavy truck. Just need to fine tune it. I have been painting pieces from the original 352 and others, including an Edelbrock SP2P for a transplant. I have been blasting and painting oil pans in search of the original one only to discover its on the truck. When I get it off Ill paint it the correct black.
chris401
Re: Carb Swap and Engine Paint
Post by chris401 »
This was supposed to be in "What Have You Done To Your Slick Today".
Limestone66
Post by Limestone66 »
chris401 wrote:This was supposed to be in "What Have You Done To Your Slick Today".
That has got to be one of the longest running posts i've ever seen. Looks good 'chris'!
Long live the 352
........Ron..........
1966 Ford F250 Custom Cab {Longbox}
1996 Toyota Camry {Wifes ride}
1940 Harley Davidson knucklehead {Retired in 2006, gave to one of my sons in 2010}
1975 Harley Davidson XLH {Groundpounder}
2005 Harley Davidson Deluxe {Nostalgia} Almost home 'girl'
In memory of Donald G. Roswell- My freind and 'brother'.
chris401
Post by chris401 »
Hawkrod
Post by Hawkrod »
You may want to do some research on that intake. They actually produce less power than the stock iron 4V. Jay Brown did a lot of dyno tests and that intake was just below the stock C4 iron intake for power (which says something! LOL). It is lousy for HP but good for torque but the stock intake was better. It is good for an RV or low RPM truck but the only real benefit is its lower weight! Hawkrod
I have never run an SP2P, so I'm just working from memory. I seem to remember Jay Brown's testing concluding that the SP2P produced the most torque under 4000 of any in this particular test. I am unable to find the actual results via a quick search.
I agree there's much better manifold choices, but if it gets rid of the original boat anchor, it is of some value!
chris401
Post by chris401 »
I have the Jay Brown book. I sought this intake out for a 3.5 stroke build posted on fepower.net "352 For The Highway". Ill miss the power but at 11,000 miles a year I wont miss the fuel consumption. This intake did move the torque peak back on the 390 stroker to about 500 @ 3000 RPM. Lots of good technical data found in that book. Well worth the money.
