Steering column wiring diagram for a 1964
Posted: July 11, 2013, 2:42 pm
by Necco-2
working on my 1964 F100 Style Side. I pulled my steering column to rebuild it. The wiring at some time before I got the truck has been butchered. I do have about 12" of factory wire before they added all green wire to what ever. Dose anyone have the color codes as to what wire goes where. I would like to put it back with the proper connections. Necco-2
Re: Steering column wiring diagram for a 1964
Posted: July 11, 2013, 6:07 pm
by Toyz
Posted: July 13, 2013, 2:42 am
by pclayton
just went out and checked my truck b/c i remembered how much of a headache wiring the column was. hopefully this helps. i have a 64 w/ factory column wiring attached to an EZ wiring harness.
here are the colors of the wires i have coming out of the column, and what i have them wired to.
Green w/ orange stripe- Left rear turn signal
Green w/ white stripe- Left front turn signal
Orange w/ blue stripe- Right rear turn signal
White w/ blue stripe - Right front turn signal
Dark Green- brake switch
Light Blue- turn flasher
Blue/Yellow striped- not wired to anything currently, but im 99% sure it's the horn
(7 wires in total)
If it looks like the old wiring harness is butchered (as mine was), I would suggest buying a new wiring harness. They aren't too expensive, and are worth every penny. I'm a broke college kid, and I saved up for a 21- circuit Ez harness (painless performance or another brand would work just as well), and it was one of the best investments I have put into the truck. I'm not very electronically inclined, but it still took only a week, working a couple hours every night (spring break) to install, and I have had zero problems so far. But again, just a suggestion. good luck with the column, and let us know if you get it figured out.
Posted: July 13, 2013, 9:31 am
by bobenhotep
If you just want to rewire the column, NPD has the turn signal cam with the column wire harness for about 30 bucks. I did mine because the cancel tabs broke off.
Posted: July 13, 2013, 1:14 pm
by Necco-2
Thanks one and all for the good info. This dose make life a little bit easier. This is a great bunch of guy that really want to help another slickster out. THANKS
