ezernut vs. autolite 1100
ezernut9mm
Sweden
Post by ezernut9mm »
round 1. ding ding.
Shadow
Re: ezernut vs. autolite 1100
Post by Shadow »
Chris Your On The Right Track. Leave It On The Cookie Sheet & Bake At 350 For 3-1/2 Hrs Or Until Carburetor Is Golden Brown. (Don't Forget To Grease Cookie Sheet With Non Stick Spray) LOL..
kstones63
Post by kstones63 »
Okay, Who won this round? :lol:
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
Brians1966
Post by Brians1966 »
Watch out for round 2 Chris that's where the 1100 will get ya !!!!
1966 F-100 LONG BED, 240cid 3 speed red and white, Red and White Interior with a Mossy Oak Seat Cover
2013 Ford F150 STX Supercab 5.0 litre
DETERMINATION: The feeling you get right before you try to do something incredibly stupid!
CONFIDENCE: Is the feeling you have before you fully understand the situation!
ezernut9mm
Sweden
well now, that went way better than expected. the problem i was having was that it wouldn't idle the same way twice. i took everything apart, blew thru all of the passages and put everything back together. the float was set a couple 32nds low so i fixed that and the anti stall (return idle) dashpot wasn't adjusted either, so i spec'd that out too. reinstalled the carb and it basically fired right up. a little idle adjustment and it was purring llike a kitten. now it idles like it should. awlrite!
Brians1966
Glad its running good :cheers:
ezernut9mm
Sweden
i haven't actually driven it yet brian. lol. don't jinx it! lol
RhodySlick'63
Post by RhodySlick'63 »
How many beers? Heha
'63 F100 292 Y-Block
