352 FE engine stroke
rust bucket
I have what i thought was a 352 Fe, but with heads off pistons don't top out. They sit at about 1/4" to 3/16" below block surface. Any ideal what is going on here. Ordered new 352 pistons and same thing going on.
Re: 352 FE engine stroke
Ive learned Ford FE's are .030 to .040 in the hole from the facory. If you had a mixed combo of 390 rods and 352/360 crank you could be as much as .068 in the hole at TDC.rust bucket wrote:I have what i thought was a 352 Fe, but with heads off pistons don't top out. They sit at about 1/4" to 3/16" below block surface. Any ideal what is going on here. Ordered new 352 pistons and same thing going on.
EDIT: Check me on the exact rod length difference. Mic the piston to deck at TDC.
