GONNA START ON THE REAR TONIGHT
Posted: March 18, 2014, 12:37 pm
by therealjoeshmoe
ANYONE KNOW HOW TO TELL WHAT GEAR RATIO YOUR REAR END IS?
Re: GONNA START ON THE REAR TONIGHT
Posted: March 18, 2014, 1:17 pm
by goldenage
If you have the driveshaft disconnected, you can just jack up the rear axle and measure the number of revolutions of the wheel per full revolution of the rear axle yoke. 3 3/4 = 3.73, 3 1/2 = 3.5, 3 1/4 = 3.25, and so on.
There's also info on the driver's door warranty tag pertaining to rear axle ratio. Should be the last set of numbers on the second line (after AXLE). You can decode it here:
http://home.earthlink.net/~threynolds2/ ... s6166.html
Posted: March 18, 2014, 2:28 pm
by therealjoeshmoe
WELL MY PUMPKIN CAME OUT OF A LINCOLN CONTINENTAL AND MY AXLE IS COMPLETELY OUT OF MY TRUCK
Posted: March 18, 2014, 2:59 pm
by bobenhotep
If the differential is sitting on the floor, draw a mark on the ring gear, and a mark on the yoke. Rotate the yoke and count how many turns it takes for the ring gear to turn once.
Posted: March 18, 2014, 3:23 pm
by Blackwaterforge
divide teeth on ring by teeth on pinion.
Posted: March 18, 2014, 3:40 pm
by therealjoeshmoe
OK I WILL TRY IT TONIGHT AND REPORT BACK LOL
THANKS
Posted: March 18, 2014, 9:39 pm
by foodstick
Joey, you KNOW we were gonna make you do some math at some point in time !
Posted: March 19, 2014, 5:53 am
by Hunter's 64
Ring gear should have the ratio stamped into the outer edge
Danny
Posted: March 19, 2014, 7:48 am
by therealjoeshmoe
foodstick wrote:Joey, you KNOW we were gonna make you do some math at some point in time !
lol ok so i tried, i dont guess it really matters what gear ratio to me.. idk why i was even asking..lol
Posted: March 19, 2014, 7:49 am
by therealjoeshmoe
Hunter's 64 wrote:Ring gear should have the ratio stamped into the outer edge
Danny
its really that easy?? lol i will look and see tonight
thanks
