Posted: August 22, 2007, 9:02 pm
by Phil
I think its technically called "disk brakes"
Posted: August 22, 2007, 9:32 pm
by az63pu
did ya install turn brakes.....
mark
Posted: August 22, 2007, 9:45 pm
by cdherman
Well, frankly, the auto adjust star mechanism is readily available from all sorts of places -- LMC has them, as well as your local autozone or advance auto. They will have to order them of course. 65-72 is the same.
here is the link:
http://www.partsamerica.com/ProductDeta ... 67&PTSet=A
If that link doesn't work , just as for Raybestos H2540 for the left and H2541 for the right.
Its called "brake Self adjuster Kit" at least by partsamerica.com
Hope that helps.
Posted: August 23, 2007, 12:02 am
by Alan Mclennan
:| :shock: :hm: :) wha.gif :( :dontknow: faint.gif
Posted: August 23, 2007, 11:51 am
by Garbz
Doc
They have three lane roads in Tuscon? Dang......
Close adjustment will get you close on the pull to center. I have the same issues on 17 during the daily commute from north Phx to the shop with Christine.
Disc brake upgrade will help too. I am still running drum drum with a power booster. Too cheap to buy an upgrade that later just may be removed and new fornt suspension put in.
Garbz
Posted: August 24, 2007, 8:05 am
by fmartin_gila
That was the main reason for my disk upgrade. More for directional control and having the safety of a dual system (I lost the brakes on a single system years ago and I found it was NOT fun). I used the ECI kit with Ford disks, Chebby calipers,a proportioning valve from a 78 F150, and a dual MC from I think a 79 or so F150. I did not install a booster, but it seems to work very well the way it is.
Fred
Posted: August 24, 2007, 2:41 pm
by Slick Fan
Doc, you might want to make sure you don't have a leaking wheel cylinder on that wheel. That makes the brakes grabby, too. :)
