Loosen rusty bolts?
Posted: April 13, 2014, 12:39 pm
by Mellvis
I found this on Facebook and was going to put it in Hints and Tricks, but I thought I would see if anyone can confirm it first:
PENETRATING OILS
Machinist's Workshop Mag recently published some information on various penetrating oils that I found very interesting. Some of you might appreciate this. The magazine reports they tested penetrates for break-out torque on rusted nuts.
They are below, as forwarded by an ex-student and professional machinist. They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment.
Penetrating oils------------Average torque to loosen
No oil used--------------516 pounds
WD-40--------------------238 pounds
PB Blaster---------------214 pounds
Liquid Wrench----------127 pounds
Kano Kroil---------------106 pounds
ATF-Acetone mix------53 pounds
The ATF-Acetone mix is a "home brew" mix of 50/50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test.
Re: Loosen rusty bolts?
Posted: April 13, 2014, 1:15 pm
by bobenhotep
I may try that. My home brew everything oil is a mix of synthetic 2 stroke oil and marvel oil. It turns purple, and it is like poor man's CLP. I can see how the acetone in the mix would make it penetrate like crazy, though.
Posted: April 13, 2014, 2:34 pm
by milomilo
I have seen this list in many places. I do know that ATF and acetone is the best. Has a short shelf life though if not sealed tight.
Posted: April 13, 2014, 2:39 pm
by Mr. Jones
Wonder if they used type-F or another type?
Posted: April 13, 2014, 5:27 pm
by Oregoon
Diesel works well, too.
Have to try the acetone/ATF blend. Great idea!
Posted: April 13, 2014, 7:27 pm
by slick4x4
I've tried about every penetrating oil or home brew I could make....
But nothing.... NOTHING beats heat
A torch just can't be touched for getting a frozen fastener to break loose
Posted: April 13, 2014, 7:45 pm
by JOSHF100
I've been using the acetone/ATF mix for the last year or so. It's cheap and does work.
I keep it in and old squeeze bottle.
It does not mix well, tries to separate.. I shake the bottle I keep it in if it has been on the shelf awhile.
Posted: April 14, 2014, 6:48 am
by Mellvis
So, it should loosen the exhaust studs on my 91 Mustang so I can pull the head without breaking anything? If something breaks I can blame you guy, right?
Posted: April 14, 2014, 8:36 am
by 36truck
Another good way is to apply enough heat to melt wax into the threads. An old candle works great.
Posted: April 14, 2014, 9:41 am
by slick4x4
I've done that too Tom
Learned it from a guy that restored old hit & miss engines
He said bees wax worked best
Candle is what I have used
Posted: April 14, 2014, 10:35 am
by Oregoon
Another great way is to apply enough heat to cut the damn thing right off... :D
