Replacing brake switch
Posted: June 12, 2014, 12:15 pm
by Bones
I need to replace the pressure brake switch on my '66 F-100. after replacing the switch, do I need to bleed my brakes?
Re: Replacing brake switch
Posted: June 12, 2014, 1:47 pm
by unibody madness
Couldnt hurt, I would. I would also do away with that type switch anyway, I have electric switches under the dash mounted on a corner bracket,activated by the brake pedal hanger
Posted: June 12, 2014, 8:41 pm
by slick4x4
I just changed mine....
I didn't bleed them & I haven't noticed any difference
Posted: June 12, 2014, 8:45 pm
slick4x4 wrote:I just changed mine....
if you dont step on the brake pedal when its out ,no fluid will leak out or air get in.
its a quick job if you have the new one in hand.
i changed out my temp gauge and lost less than a shotglass of coolant.
Posted: June 12, 2014, 8:48 pm
by slick4x4
That's exactly what I did....
As soon as the old one out...good one (I have lots of spare parts) back in
Posted: June 13, 2014, 12:01 am
by Bones
Thanks, Guys. got 'er done in just a few minutes and brakes lights are back!
Just a 'spit' of fluid leaked out!
Posted: June 13, 2014, 10:02 am
by Uncle Skip
Guys, Ron Francis Wiring has a "low pressure" brake switch with a neat little connector that you should consider. I noticed on my own master cylinder that sometimes I had to really press down on the brakes to get the brake light to come on. I don't know if that is or was a function of the disk brake swap or not, but the new switch from Francis cured my problem.
(and about the same price as the original).
Posted: June 13, 2014, 5:41 pm
by Shadow
Uncle Skip wrote:Guys, Ron Francis Wiring has a "low pressure" brake switch with a neat little connector that you should consider. I noticed on my own master cylinder that sometimes I had to really press down on the brakes to get the brake light to come on. I don't know if that is or was a function of the disk brake swap or not, but the new switch from Francis cured my problem.
Skip's Right. I Used One Of These On My Truck When I Upgraded The Brakes & They Work Great!..............
