65 F250 with a 67 F250 Master cylinder
Posted: August 2, 2014, 10:29 am
by GarageTime
Hey to all. First post. Thanks for your time. I've got a 1965 F250 with stock drums all around. I wanted to upgrade to a dual pot master cyl. The 1967 F250 had drums all around and a dual pot master.
I have a NOS 67 master. I dropped it in and put a longer push rod in to bring the pedal back up to correct the height. Just the slightest bit of free-play.
Everything is working as should. I did a "panic brake" test on a gravel drive. All four locked up and left equal slide marks. Steering wheel never pulled L or R.
So now the questions. (assuming I have the correct master cyl. with built in residual valves) Am I good to go? I've read that as long as long as I have the residual valves in place a proportioning valve is not needed on a all drum system. Is this correct? Some say otherwise.
Thanks again for any input or criticism.
Re: 65 F250 with a 67 F250 Master cylinder
Posted: August 2, 2014, 10:39 am
by LM14
The '67 MC should have the 10# residual valves built in. If you don't have too much pedal travel or have to pump it up, go enjoy your ride!
Posted: August 2, 2014, 11:14 am
by GarageTime
LM14 wrote:The '67 MC should have the 10# residual valves built in. If you don't have too much pedal travel or have to pump it up, go enjoy your ride!
Pedal is high and tight. No sponginess. No pumping. Now I just need to get my brake light switch install done.
Thanks SPark
Posted: August 5, 2014, 12:54 pm
by Blackwaterforge
GarageTime wrote:Now I just need to get my brake light switch install done.
I used a electric brake light switch and mounted it in place of the rubber bumper on the brake pedal.
Posted: August 7, 2014, 9:09 pm
by GarageTime
I was going to install an inline T at master and screw my pressure switch in and reconnect wires. 3/16 x 3/16 x 1/8 female NPT.
Any thoughts on this method?
Posted: August 7, 2014, 9:29 pm
by ezernut9mm
seen it done a bunch of times. haven't heard of any problems associated with it.
Posted: August 7, 2014, 9:44 pm
by foodstick
You are off to a great start ! Nothing like good brakes on these trucks !
Posted: August 7, 2014, 10:04 pm
by GarageTime
Thanks for replies
The manual steering keeps my heart rate up.
But I'm getting too old to be "Living on the edge" with a bad brake set-up.
Posted: August 8, 2014, 11:21 pm
by bobenhotep
I mounted a switch to work off of the bumpstop bar on the brake pedal. I put it through the bracket above it. I don't like the pressure operated switches, they start leaking after a while and if they were so great they would have kept using them.
Posted: August 9, 2014, 11:08 am
GarageTime wrote:I was going to install an inline T at master and screw my pressure switch in and reconnect wires. 3/16 x 3/16 x 1/8 female NPT.
thats how i did it, still working fine after 14 years.
on my 65 towtruck i removed the rubber from the pedal stop
(different style from the one above)
it worked but the pedal having no rubber banged against the switch and broke it after a while. i redid it using a full nut rather than the thin one supplied with the switch and that fixed the problem but the pedal still hit the switch harder than i liked
