D1500 rotors / stock ford rims
mercman64
Post by mercman64 »
Can't get the wheels on the Dodge rotors.....I need a inside / outside caliper to measure the exact amount of interfereance ....but the opening in the wheel will NOT go over the centering hub on the rotor.....is this common ? .....it's close....but .....ideas ?
1964 Mercury Monterey Convertible
1962 F100 unibody LWB BBW "Show Truck"
1966 F100 short box "daily driver"
1963 F100 unibody "project truck"
2010 Dodge Challenger R/T
Re: D1500 rotors / stock ford rims
guessing you installed a dakota kit
dunno about the new stuff but about 25 years ago i had a dodge van, got a flat and the wheel would not come off.
drove up and down the dirt road with no lug nuts then jacked it up again and took many whacks with a sledgehammer to get it off.
thats when i noticed it was a ford wheel.
guessing again the rotor hubs on dodge have not changed in the years.
36truck
Post by 36truck »
Ford had a big center hole starting in the mid 70's & a small center hole on the older cars.
Tom Williams
mercman64
Post by mercman64 »
All I read about this Dakota IFS.....never mentioned that the wheels wouldn't fit .....hey LM 14' what did you do ? .....anybody out there have the same glitch ?....uncle Skip ?
jkimbrel65
Post by jkimbrel65 »
I have a Dakota clip with d1500 rotors an running stock outies. I had my rotors turned down to fit the wheel.Took the rotors and wheel to machine shop. Cost was maybe 25 per rotor
Mike
I tried being normal once...
mercman64
Post by mercman64 »
Gotcha, when you say outies......are they stock looking wheels that let you run the dog dish hubcaps ?
Post by Gritsngumbo »
Not to butt in, but "outies" are the wheels with the knobs on the outside of the center ring (66 and later trucks), it's the "innies" that the dog dish caps fit. Little nubs on the inside to hold the caps.
Johnny Canuck
Post by Johnny Canuck »
this is the best thing i ever saw to describe innies and outies, thanks to Keith at Fordification, gem of a guy
http://www.fordification.com/tech/hubcapID.htm
--->scroll to the bottom of the page. There are bottle cap hubcaps that fit both innies and outies, but now you know what they are.
mercman64
Post by mercman64 »
Thanks ! That wheel chart is a load of info....now I know.....I know I have to take my new rotors to the machine shop......and I want wheels that take innies !
LM14
Post by LM14 »
I used Dakota hubs and aftermarket 5 on 4.5" wheels. Sorry, can't help you.
