Newbies 66
Posted: August 31, 2014, 11:18 pm
I figured I should stop lurking and Introduce myself. As a kid my dad had 66 Step side and I thought it was the coolest thing ever. Over the years I have had several projects, most of my experience comes in the way of off-road Jeeps. I always enjoyed building them, especially the fabrication aspects of each project. I got tired of taking the jeeps out just to beat them up and not being able to enjoy them on an everyday basis. I have been on the search now for long time and a search lead me to Idaho where I found my truck. As luck would have it the same weekend I found it I was heading to Idaho, My Wife and I took a 2 hour detour and picked it up. I drove it all the way back to Utah, cruising at 70 without any issue at all. I was giggling all the way home, scheming and planning my build. I guess you could say I have it all in my head in what and how I will do it. Im a full time student, and I work two jobs. I have 3 boys, but the luckiest guy in the world because I have a wife who understands and loves it just as much or more than I do. Because of current status in life the build will be done in stages. Right now its a stock truck, the previous owner had done a few things to it, rust is not bad (could be worse) a lot of the surface body work is done, but all the stuff you don't see has been neglected. I replaced the seat last week, I went to the pick-n-pull and pulled a 50/50 split bench seat out of a 94 f250 and it bolted right up. At least now its comfortable to drive. Its running the 352 with a C/4 trans.
So for stage 1 of my build heres my plan, I've got a crown vic front clip sourced, just need to pick it up. I plan on doing discs all the way around. Currently a Dana 60 is in the rear. This is up for debate, do I keep it, four link the (using bags, or a donor coil spring) or do I go with the independent rear suspension out of the T-bird. The 60 plan seems the easiest, but man that IRS is tempting. I want to bag it, but that may come later on down the road a ways.
Anyway, Im excited to be a part of this forum and get my build underway.
