Will this PS Bracket Work?
Jlincks
Post by Jlincks »
I need to get a bracket for my power steering pump. The engine is a 289 from a 65 galaxy and I'm not sure if this bracket is the one i need?
Re: Will this PS Bracket Work?
Try it an see if the pump lines up with the crank pulley.
Roger Carter
Post by Roger Carter »
Ford made a lot of different power steering pump brackets for several different engines that look similar to the one pictured.
If possible, try it and see if/how it fits.
Good luck.
Roger Carter
