crown vic center line
Posted: December 18, 2014, 3:18 pm
by Voodoo66
Of those you whom have completed the crown vic suspension swap....how far forward did you move the axle center line?
Re: crown vic center line
Posted: December 20, 2014, 11:19 am
by luckystiff
how low you plan to go has a little bit to do with it. the lower you go the more you move it. just going crossmember to frame 1.25-1.5". cut coil(s), bagged, etc 1.5-2". so if you want a safe middle ground figure 1.5". no use trying to get perfect since you're putting in a suspension thats 5" to wide................
Posted: December 20, 2014, 11:55 am
by randyr
It would also depend on the year of your truck.....the centerline of the '65/66 is already moved an inch further forward than the previous models.....
Posted: December 21, 2014, 6:16 pm
by William-in-St George
Pictures and info on your wheel choice.
