OK I HAVE A QUESTION!
Posted: February 25, 2015, 2:25 pm
by therealjoeshmoe
I NEED TO REPLACE MY RIGHT FRONT HUB(BEARING HOLDER) THE BEARING WENT OUT AND WALLERED OUT, SO BEARING FITS IN THERE LOOSELY NOW.. BUT HERES MY QUESIAN, I HAVE A 62 F100 STRAGHT AXLE THAT I WAS THINKING MAYBE THE HUBS ON IT WOULD FIT MY 65 TWIN I BEAM? ANY IDEAS??
Re: OK I HAVE A QUESTIAN!
Posted: February 25, 2015, 3:15 pm
i think it will.
pretty sure the spindles are the same.
Posted: February 25, 2015, 5:09 pm
by therealjoeshmoe
awesome!
Posted: February 25, 2015, 6:18 pm
by skidoorulz
Why can't you get new bearings and races? Hammer out the old race press the new one in and be done with new bearings in it.
Posted: February 25, 2015, 10:41 pm
by 6166 Junkyard Dog
Hub/Drum assembly 64-67 only,, 61-63 is another
Posted: February 26, 2015, 8:17 am
by bruceandersson
If you're sticking with the drum breaks, someone here ought to have a spare hub from a disk conversion. Or maybe this should be the motivation o upgrade the system?
Posted: February 26, 2015, 10:05 am
by therealjoeshmoe
skidoorulz wrote:Why can't you get new bearings and races? Hammer out the old race press the new one in and be done with new bearings in it.
well where you put the bearings in it is wollered out and the race does not fit tight, the race spins in the hub with the bearing, ive got a old f100 straight axle im gonna see if it will work..
Posted: February 26, 2015, 11:54 am
by LM14
They list a different disc brake kit for a '61-64 straight axle truck than they do a 65 and later. I think the spindles are different.
Correction, just read Tom's post above and may be off a year on the kit breaks.
I think they are different.
Posted: February 26, 2015, 12:52 pm
by joeymac64
LOCTITE makes a product to to use in the bearing races to tighten them up
I used it in a king pin bushing I couldn't stop from turning trying to ream it
works great I will post the number and type when I go out to the shop
Posted: February 26, 2015, 3:22 pm
by joeymac64
you can use Loctite 640 or 660 retaining compound to reinsert your bearing race . it is made for press fit or slip fit
and provides a sheer strength of 4000 lbs
Re: OK I HAVE A QUESTION!
Posted: February 26, 2015, 9:13 pm
HERE IS What I would use on races,, take a center punch in a few places, then mix a little JB Weld put little on the race then install the race and let dry,, Both my races on my 56 with disc rear I had to do this and that has been 20+years ago
Posted: February 26, 2015, 10:16 pm
by Toyz
Tom, I'm hoping you mean "take a center punch to the spindle at bearing race location". I suspect Joey would need a surface upset about the size of the Grand Canyon if he has my luck!
