Rubber Seals between the inner fenders and firewall
Lancer
Post by Lancer »
Does anyone repro these? Been looking all over, have not found them.
Just wondering if I'm going to have to make my own.
Thanks, Lancer
kstones63
Re: Rubber Seals between the inner fenders and firewall
Post by kstones63 »
I used the insulating foam that you can get at Home Depot for weather stripping seals. I believe that this was a 3/4" square foam. I glued it on to the fender with the 3M black weatherstrip adhesive.
So far it has worked out really well.
This isn't factory correct if you are wanting that but it does work.
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
Lancer
Post by Lancer »
Thanks, that will do the trick.
64 f100
Post by 64 f100 »
If, you look closely at the originals, I believe those were made from inner tubes. I am going to attach mine with very short round head screws.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
rderr
Post by rderr »
Just curious, what was the original purpose for them?
Shadow
Post by Shadow »
Make A Template From The Original And Transfer To An Inner-Tube. Then Use Stainless Wire Threaded Through The Staple Holes To Fasten To The Firewall............
64 f100
Post by 64 f100 »
rderr wrote:Just curious, what was the original purpose for them?
These seals are to help keep flying objects such as mud and water from coming into the engine compartment from the wheels.
1961 F350
1991 Capri
2011 F250
2004 Lexus
