Page 1 of 2
Almost running
Posted: June 23, 2015, 5:38 pm
by wndsofchng06
So she wants to start.... Fires every time but won't keep going... Any ideas?
http://s1198.photobucket.com/user/Matth ... g.mp4.html
Re: Almost running
Posted: June 23, 2015, 5:40 pm
by wndsofchng06
And there is fuel all the way up to the carb...
Re: Almost running
Posted: June 23, 2015, 5:48 pm
by PowerStrokeUni
Check the resister in the coil circuit.
Re: Almost running
Posted: June 23, 2015, 5:57 pm
by wndsofchng06
There's no resistor on the fire wall or under the hood...... The wires run straight from inside the cab out to the coil. Where would it be?
Re: Almost running
Posted: June 23, 2015, 8:40 pm
by PowerStrokeUni
How about a simpler question.
Do you have power to the coil with the ignition switch turned on? Or just in the start position?
You only have two things to chase at this point, Spark and fuel. If it doesn't have a restriction (stuck needle / seat) in the carb. It is probably ignition, bad coil, bad power, dead condenser/points.
Re: Almost running
Posted: June 24, 2015, 3:29 am
by SLICKCOLLECTOR
the resistor is a wire. a pink resistor wire. under the dash.
jim
wndsofchng06 wrote:There's no resistor on the fire wall or under the hood...... The wires run straight from inside the cab out to the coil. Where would it be?
Re: Almost running
Posted: June 24, 2015, 7:04 am
by wndsofchng06
Well be checking this today. I noticed the ignition is a rat's nest of aftermarket wires so who knows if the coil is getting power or enough power or what. Going to test by got wire today.
Re: Almost running
Posted: June 24, 2015, 7:39 am
by 64 f100
The resistor wire may not be pink t look at. Normally it is covered by a cloth type blackish covering. Ignition switch should be a wire coming from the it, that runs a few inches and then has a single plug in . The resistor wire is what is connected to this and should run to another plug that is also under the dash. New ones can be had for roughly 15 to 29$. Check voltage going to the coil , it should be about 8 volts. If the engine starts but dies when you let up on the starter, then there is another problem previously mentioned.
Re: Almost running
Posted: June 24, 2015, 6:14 pm
by wndsofchng06
Was definitely the power wire on the wrong leg of the after market ignition switch. She is running great now! Brakes were kind of scary though.
Re: Almost running
Posted: June 24, 2015, 6:15 pm
by wndsofchng06
Re: Almost running
Posted: June 25, 2015, 9:57 am
by orangeRcode
She sounds awesome!
Re: Almost running
Posted: June 25, 2015, 10:52 am
by The Big M
Sure does!
Re: Almost running
Posted: June 25, 2015, 12:02 pm
by wndsofchng06
Thanks guys. Say, this truck has a dual master and no provision for brakes lights. What do you think of adding an online pressure switch?
Re: Almost running
Posted: June 25, 2015, 12:56 pm
by LM14
I just put a "T" in a line for a pressure switch.
Re: Almost running
Posted: June 25, 2015, 1:05 pm
by wndsofchng06
That's what I was thinking! Thanks!
Re: Almost running
Posted: June 25, 2015, 1:59 pm
by unibody madness
I replaced the pressure switch with a simple momentary normally closed switch activated by the brake pedal stop.
Re: Almost running
Posted: June 25, 2015, 2:19 pm
by wndsofchng06
But don't you have to fab a bracket then?
Re: Almost running
Posted: June 28, 2015, 1:11 pm
by wndsofchng06
So there is a brake light switch fabbed up, and starting to trace the nest of wires.... I now have head lights, wipers, gotten, and all dash functions. I still have four wires at the ignition switch that seem to have no home ( all coming off the original harness) and two wires blank behind the dash. Also can't find the coil resistor. Have 12v at the ignition switch and nothing at the coil.... Is it under the electrical tape somewhere?
Re: Almost running
Posted: June 29, 2015, 7:11 am
by bruceandersson
It always amazes me how the wiring of older vehicles can get trashed over time. Most often from putting in stereos... The aftermarket switches are also confusing when you can order the original from NAPA for probably the same price. It is good that the original harnesses are color coded.
Re: Almost running
Posted: June 29, 2015, 7:56 am
by wndsofchng06
Yes! The radio in this one is a real treat... Giant 8 track player, that they hacked the dash to install....
