223 -> 300 distributor swap question
Posted: July 10, 2015, 8:03 pm
by cdc3jj
I'm considering swapping my 223 loadomatic distributor to one from a 300 and I am wondering how much work will be involved. I pulled my loadomatic distributor today to see if it was a 1/4" or 5/16" shaft. It's a 5/16" so I don't think I would have to mill or modify the 300 distributor shaft. I'm guessing I might have to cut it down a little but that's not a big deal. My question is: will I still have to change the 223 gear over or will the stock 300 gear be ok? I've read several of the tech posts but they all address the older 223 with the 1/4" drive fuel pump.
Re: 223 -> 300 distributor swap question
Posted: July 10, 2015, 9:44 pm
by bobenhotep
If you have the 5/16 inch oil pump drive the gear off of the distributor will have to be swapped, but it should fit on the 300 distributor without having to machine/ file/ drill anything. Way easier than if you have a 63 or earlier 223.
Posted: July 11, 2015, 8:58 am
by ezernut9mm
I have a Mallory unilite for a 223 I'll sell ya real cheap.
Posted: July 11, 2015, 9:31 am
by cdc3jj
Thanks for the info. I was planning on swapping to the 300 and installing a pertronix in it at the same time. I'm not super familiar with the Mallory stuff. Seems like that requires an ignition box doesn't it? Thanks again
Posted: July 13, 2015, 11:01 pm
by ezernut9mm
i was kinda smartassing, keep on going in the direction you are going. its a better one. lol
