Straight axle tin boltup to twin i beam cab??
Posted: December 3, 2015, 7:53 pm
by jamesdfo
So, I asked Brian if the front clip off my '64 M-350 would bolt up to the firewall of a 65-66 twin i beam cab, he seems to think no, and I wouldn't be that surprised if that's the case.
I Don't have one of each side by side to compare, so has anybody actually attempted this??
Mostly thinking of the inner fenders & rad support, we already know 61 thru 66 fenders interchange.....
James
Re: Straight axle tin boltup to twin i beam cab??
Posted: December 3, 2015, 8:26 pm
by rbeck204
James,
61-64 Inner fenders and core supports are different than 65-66. Inner fenders for 65 and 66 are also slightly different from each other but will interchange with a little work.
Sounds like your part collecting is getting serious. Good luck
Posted: December 3, 2015, 9:03 pm
by jamesdfo
Rich: Thanks for confirming what Brian already told me, suspected as much, just wanted to be sure:)
**Oh yah, RICH, check your email!
Posted: December 4, 2015, 5:54 pm
by skidoorulz
If you have the whole front clip there is no reason why it wont work. The pre 65 inner fenders are different but are actually bigger than the 65 66. I am sure the 64 and older outer fenders will bolt right up to yours as I used a 66 fender on my 64 with no modifications other than welding the 3 holes shut that were not needed in 64 for the badges. Now onto the core support. Unless the frame rails are a different width on a 65 66 than early years. which I don't believe they are. There should be no reason that it won't bolt to the frame. Hood hinges are the same headlights are the same. Park lights are in a different location but all you may need to do there is lengthen the wires to these if they are to short. The front bumper mounts a little different but I think the front bumper off the 64 will bolt right up minus the 64 brackets. I'd give it a try.
Posted: December 5, 2015, 7:42 am
by Toyz
The complete clip readily interchanges. As noted, fenders are the same, and there are no other fasteners between cab and inner fenders except the flexible strap. '64 front bumper is the same, so, as noted, it can also be used sans brackets.
Posted: December 5, 2015, 8:08 am
by 6166 Junkyard Dog
INNER FENDERS They way the bolt on is a problem........ 65/66 bolt on to the cab with 3 bolts,,, 61/64 bolts on with a bracket,, that is one way to tell the difference at back 61/64 fenders are held on by the little bracket with 2 bolts that is bolted to the cab with a caged nut in the cab,, one answer is after bolting all that up, weld the bracket to the cab so it can be attached back these and see 65/66 trucks there is only one bolt back at the cowl on the outer fender
