spark plugs
Posted: December 20, 2015, 5:56 pm
by matt
Hello all. I have a 1964 ford one tonne that I have been trying to get back on the road. It was my dads truck and has been sitting since he died 18 years ago. I finally got it running and it was running really good. Then all of a sudden it back fired and quit. Pulled all the spark plugs and all of them are no good. (They are brand new) is there something that may cause a spike in power frying them? I changed all the wires, cap, rotor and took the points out and put a ignitor in its place when I first got it running. Any ideas? Thanx ps. I know all the plugs are bad because I started my running vehicle and they had no spark
Re: spark plugs
Posted: December 20, 2015, 9:22 pm
by jamesdfo
Matt: First off, welcome.gif
I'm going to take a wild guess that you might be in/around Red Deer??
If so, I'm likely the one that told you about this place on the phone a few weeks back? :)
I'm no mechanic, but when you have autobody questions, I'm your man! lol
Cheers!
James
Re: spark plugs
Posted: December 20, 2015, 9:24 pm
by matt
Haha. That would be me.
Re: spark plugs
Posted: December 21, 2015, 4:41 pm
by charliemccraney
The odds of all plugs going bad at the exact same time are astronomical. It is most likely something that they all have in common, bad engine ground, coil, coil wire, distributor, distributor cap, ignitor, etc.
It's possible that the actual cause of the problem resulted in fowled plugs which might appear to be bad but only need to be cleaned.
Re: spark plugs
Posted: December 21, 2015, 7:32 pm
by matt
Thinking it could be that they need cleaned. Bought a new set I will put in tomorrow. Just dont understand why it would happen so quickly. Sure the length of time its been sitting has contributed to it. Am assuming there is probably some crap sitting in the tank.
Re: spark plugs
Posted: December 21, 2015, 8:07 pm
by tomrooster
When you get it started check your timing , that could be why it backfired. Tom
Re: spark plugs
Posted: December 21, 2015, 9:56 pm
by jamesdfo
Matt: To take the sh!tty gas/varnish that may be in the tank out of the equation, take a smal jerry can and run a short length of fuel line from the jerry can to the fuel pump. In all likelyhood that gas tank is going to need to be hot tanked, and probably treated with redkote or something similar. (if youdon't know of any good shops in RD for this, PM or call me & I can send you to a good rad shop here in Edmonton.)
James
matt wrote:Thinking it could be that they need cleaned. Bought a new set I will put in tomorrow. Just dont understand why it would happen so quickly. Sure the length of time its been sitting has contributed to it. Am assuming there is probably some crap sitting in the tank.
Re: spark plugs
Posted: December 21, 2015, 10:47 pm
by matt
Will try it out. Thanks james
